# AI Center™ permissions
> An AI Center™ project with a dataset is required to run a Task Mining project. AI Center™ model packages and pipelines are used to generate analysis results from a dataset that's generated by users in Task Mining projects. An AI Center™ project and the required permissions are automatically assigned when a project is created in Task Mining.
If there are issues with uploading data on generating analysis results in a Task Mining project, it's best to verify the permissions shown in this article.
## User management via UiPath Automation Cloud
Because Task Mining is a service within Automation Cloud please take into account that all the users involved in the discovery process need to have an account in Automation Cloud.
## How to grant AI Center permissions in Orchestrator
Task Mining relies on AI Center™ to store the recorded data and run the ML Pipelines to generate discovery results. To operate Task Mining projects successfully, the following permissions need to be applied in Orchestrator at the tenant level.
To assign AI Center™ permissions, you must first create a tenant role in Orchestrator. To create the role go to Orchestrator &gt; Tenant &gt; Manage Access &gt; Roles &gt; Add a new role &gt; Add a tenant role.
![Add a new role in Orchestrator](https://dev-assets.cms.uipath.com/assets/images/task-mining/task-mining-131053-6684f89b.webp)
Name the role and then select the appropriate permissions from the list above. Select the **Create**button.
![Select permissions for the role](https://dev-assets.cms.uipath.com/assets/images/task-mining/task-mining-131162-e62951c7.webp)
Once created, the role should be applied to all the users in your study. This can be done within the **Manage Access** section in the Orchestrator Tenant view. Roles can be assigned to individual users or to a group.
![Assign roles](https://dev-assets.cms.uipath.com/assets/images/task-mining/task-mining-131193-61f9a840.webp)
### Required permissions
To learn more about permissions in AICenter, review [the AI Center® permissions guidance](https://docs.uipath.com/ai-center/automation-cloud/latest/user-guide/about-ai-center#permissions) in the AI Center documentation.
#### Project administrator
This grants Task Mining administrators the ability to create and manage the lifecycle of AI Center™ projects and run ML pipelines.
* **ML Logs**: View
* **ML Packages**: View, Edit, Create, Delete
* **ML Skills**: View
  ![Tenant permissions for ML Logs, ML Packages, and ML Skills for Project admins](https://dev-assets.cms.uipath.com/assets/images/task-mining/task-mining-133392-23937599.webp)
#### Business analyst
This grants Task Mining business analysts the ability to review discovery results including screenshots.
* **ML Logs**: View
  ![Permissions for ML Logs, ML Packages, and ML Skills for Business analysts](https://dev-assets.cms.uipath.com/assets/images/task-mining/task-mining-131285-c4dbdd06.webp)
#### Recording user
This grants Task Mining users the ability to upload recorded data to AI Center™.
  ![Permissions for ML packages for Recording users](https://dev-assets.cms.uipath.com/assets/images/task-mining/task-mining-131537-91741f02.webp)
