# Group Policies
> If your organization uses Group Policies for browser extension management then follow the instructions from this page to ensure that the extension for Edge is installed correctly.
The list of active policies on your machine can be viewed in Edge by navigating to `edge://policy`.
![docs image](https://dev-assets.cms.uipath.com/assets/images/studio/studio-402066-1b45fab0.webp)
You can find out more information about Edge policy management [on this page](https://docs.microsoft.com/en-us/deployedge/microsoft-edge-policies).
## Group Policies That Affect the UiPath Extension for Edge
### ExtensionInstallForcelist
The [ExtensionInstallForcelist](https://docs.microsoft.com/en-us/deployedge/microsoft-edge-policies#extensioninstallforcelist) policy controls which extensions are force-installed in the browser.
This policy must contain the ID of the UiPath Extension for Edge.
For machines that are joined to a Windows Active Directory follow the installation steps for the Group Policy [Offline](extension-for-edge-chromium.md) installation method.
For this installation method the [ExtensionInstallForcelist](https://docs.microsoft.com/en-us/deployedge/microsoft-edge-policies#extensioninstallforcelist) policy must contain the value:
`ndmegdjihnhfmljjoaiimbipfhodnbgf;file:///C:/ProgramData/UiPath/UiPath.Common/EdgeExtension_SelfHosted/extension_manifest_edge.xml`
For machines that are not joined to a Windows Active Directory follow the installation steps for the Group Policy [Online](extension-for-edge-chromium.md) installation method.
`kcgmcmhhfbcacnlnopghneecffhelmhe;https://edge.microsoft.com/extensionwebstorebase/v1/crx`
### DeveloperToolsAvailability
If the UiPath Extension for Edge is installed using [Group Policy](extension-for-edge-chromium.md#install-from-group-policy) then the [DeveloperToolsAvailability](https://docs.microsoft.com/en-us/deployedge/microsoft-edge-policies#developertoolsavailability) policy must be set to the value `1` (Allow usage of the Developer Tools) to enable the full extension functionality.
See more details about this setting in the [troubleshooting](extension-for-edge-chromium.md#troubleshooting) page.
### NativeMessagingBlocklist
The [NativeMessagingBlocklist](https://docs.microsoft.com/en-us/deployedge/microsoft-edge-policies#nativemessagingblocklist) policy prevents the UiPath NativeHost (`ChromeNativeMessaging.exe`) from working.
You can allow the UiPath NativeHost by adding the value `com.uipath.chromenativemsg_v2` to the [NativeMessagingAllowlist](https://docs.microsoft.com/en-us/deployedge/microsoft-edge-policies#nativemessagingallowlist) policy.
### ExtensionInstallBlocklist
The [ExtensionInstallBlocklist](https://docs.microsoft.com/en-us/deployedge/microsoft-edge-policies#extensioninstallblocklist) policy prevents extensions from being installed on the machine.
To fix this, you can either:
* Install the UiPath Extension using [Group Policy](extension-for-edge-chromium.md#install-from-group-policy).
* Or allow the UiPath Extension to be installed from the Edge Web Store by adding the value `kcgmcmhhfbcacnlnopghneecffhelmhe` to the [ExtensionInstallAllowlist](https://docs.microsoft.com/en-us/deployedge/microsoft-edge-policies#extensioninstallallowlist) policy.
### NativeMessagingUserLevelHosts
If the [NativeMessagingUserLevelHosts](https://docs.microsoft.com/en-us/deployedge/microsoft-edge-policies#nativemessaginguserlevelhosts) policy is set to `false`, it prevents the UiPath extension from working correctly in the case it was installed without administrator privileges.
* Set the **NativeMessagingUserLevelHosts** policy to `true`.
### BlockExternalExtensions
If the [BlockExternalExtensions](https://docs.microsoft.com/en-us/deployedge/microsoft-edge-policies#blockexternalextensions) policy is set to `true`, it prevents the UiPath extension from being installed in any other way except for by policy.
To fix this you can either:
* Set the **BlockExternalExtensions** policy to `false`.
### ExtensionAllowedTypes
If the [ExtensionAllowedTypes](https://docs.microsoft.com/en-us/deployedge/microsoft-edge-policies#extensionallowedtypes) policy is set, it prevents the UiPath Extension from being installed. To fix this, you must add the value `extension` to the **ExtensionAllowedTypes** policy.
### ExtensionSettings
If the [ExtensionSettings](https://docs.microsoft.com/en-us/deployedge/microsoft-edge-policies#extensionsettings) policy is set to block all extensions it will prevent the UiPath Extension from being installed.
