# Deploying a solution
> Deploy a solution package to an Orchestrator tenant in Automation Suite.
Deploying a solution means creating a deployment of a solution package in Orchestrator. For more information about solution deployments, see [Understanding the solution development lifecycle](https://docs.uipath.com/solutions-management/automation-suite/2.2510/user-guide/solutions-management-overview).
This step is typically performed by an administrator.
A solution package published from Orchestrator or Studio Web can be deployed to either an Orchestrator tenant or a Personal Workspace. If you publish a solution package from Studio Web to your Personal Workspace, deployment occurs automatically. If any issues occur, see [Debugging solutions](https://docs.uipath.com/studio-web/automation-cloud/latest/user-guide/debugging-solutions) in the Studio Web user guide.
To deploy a solution in Orchestrator, follow the steps below.
## Step 1. Select the deployment source
1. Select the **Solutions** tab at the tenant level.
2. Select or provide the solution package. Consider the following scenarios:
   * If the package already exists in your tenant or Personal Workspace, select an existing solution package.
   * If you want to create a new package from your project, create a new solution package.
   * If you are transferring a package from another tenant or environment, upload a solution package.
3. Deploy the desired version using any of the following options:
   * Select **+ Deploy** from the **Deployments** tab.
   * Select **Deploy** from the corresponding row in the **Packages** tab.
   * Select **More actions** (the menu icon ⋮) in the **Packages** tab and choose **Deploy**.
## Step 2. Configure deployment details
On the **Deploy a solution** page, review and update the deployment details as follows:
1. First, fill in the following required fields:
   * **Package**: Choose the package you want to deploy. Once you select a package, the **Version** field displays details such as package version, publish date, description, and author.
   * **Deployment name**: Enter a unique name.
   * **Location**: Choose where the solution folder will be created - whether to **Install as root folder** or select an existing folder.
     For more information about folders, see [Folders](https://docs.uipath.com/orchestrator/automation-suite/2.2510/user-guide/folders) in the Orchestrator user guide.
2. For the optional fields, expand **Advanced Options**.
   1. If needed, turn on the **Use custom solution folder name** toggle and enter the appropriate solution folder name.
   2. In the **Activation strategy** section, select one of the following:
      * **Now**: activates the deployment immediately.
      * **Later**: installs the deployment but leaves triggers disabled.
3. Select **Deploy** to orchestrate the deployment.
If additional configuration is required, the configuration screen is displayed.
## Step 3. Review, configure, and validate the solution
After configuring the required and optional fields on the **Deploy a solution** page, you can:
* Select **Deploy** to start the deployment immediately, or
* Select **Review** to open the **Solution Installer** and further configure the solution components.
In the **Solution Installer**, you can:
* Review solution components, properties, and files
* Filter properties from the **Display** dropdown
* Link existing components
* Save the solution as a draft
* Validate the deployment configuration
### Re-use and link to existing components (optional)
During the deployment of a solution, all required components are created in the target environment by default. But if some required components already exist in the target environment, you can link the solution to those components instead of creating new ones.
Consider the following before proceeding:
* This functionality is available for Assets, Storage buckets, Webhooks, and Queues.
* If a component with the same name already exists in the tenant, you can:
   * Keep the existing component and not create an additional one.
   * Keep the existing component and add additional new fields from the solution (existing fields are not altered).
   * Rename the conflicting resource in the respective service.
   * Rename the resource in the solution deployment, if possible.
To link an existing component, follow the steps below.
1. On the **Deploy a solution** page, select **Review**.
    You land in the **Solution Installer**, on the **Components** page.
2. On the left side, select the component you need and then select **Link to existing**.
3. On the **Link to existing process** dialog, select the component you want to link to.
4. Select **Link**.
## Step 4. Monitor a deployment's status
After selecting **Deploy** to orchestrate the deployment, you can begin monitoring a deployment's status.
A deployment can succeed or fail. You can monitor the deployment status from the deployment page.
| Status | Behavior |
| In progress | The deployment operation is in progress. |
| Successful | The deployment completes successfully and all components are deployed. |
| Failed | The deployment fails and an automatic rollback is performed. |
| Failed Rollback | The deployment fails and some components require manual cleanup. |
For details about all statuses, see [Checking the deployment status](https://docs.uipath.com/solutions-management/automation-suite/2.2510/user-guide/checking-the-deployment-status#checking-the-deployment-status).
## Step 5. Activate deployments
:::note
If the solution contains apps and they are not activated using the provided link, the deployment activation fails.
After a deployment finishes successfully, Orchestrator automatically evaluates activation readiness.
The deployment appears in the **Deployments** tab with one of the following statuses:
* **Inactive (Ready to activate)**: No additional configuration is required. Select the **More actions** icon, and then select **Activate deployment**.
* **Inactive (Needs setup to activate)**: Additional prerequisites must be completed:
   1. Select the **More actions** icon and then select **Set up activation**.
   2. Review activation validation results.
      * Add accounts and assign roles.
      * Add machines to solution folders.
      * Define account-machine mappings, if needed.
      * Define asset values per robot, if applicable.
      * Activate apps used in the solution.
      * Fill in bindings for process-type components, if applicable.
   3. Resolve listed items.
   4. Select **Validate**.
   5. Select **Activate**.
