# Scheduling Data Runs
> Scheduled data runs for Process Mining on Automation Suite: automate regular extraction and transformation refresh cycles for production process apps.
In production environments, typically data for process apps is refreshed at regular intervals. For example, every day, or every week. To make sure this happens, the extraction process can be scheduled which has to trigger the app to start data transformation and refresh the data in the Process Mining process app. Refer to [Retrieving the SQL Server database parameters](https://docs.uipath.com/process-mining/automation-suite/2024.10/user-guide/retrieving-the-sql-server-database-parameters#retrieving-the-sql-server-database-parameters)
In most cases Windows Task Scheduler is used to schedule the extraction script or process at regular intervals.
## CData Sync Scheduler
If data extractions are done with CData Sync, you can use the CData Sync Scheduler to define a schedule to run the extraction job on a regular interval, check out [Run the job](https://docs.uipath.com/process-mining/automation-suite/2024.10/user-guide/run-the-job#run-the-job) - **Scheduling jobs**.
