# Intercom authentication
> Connect UiPath to Intercom using OAuth 2.0 with your client ID and client secret.
## Prerequisites
To create a connection, you need the following credentials:
* Client ID
* Client secret
The connector uses OAuth 2.0 authentication. To learn how to retrieve credentials, refer to the Intercom [Setting up OAuth](https://developers.intercom.com/docs/build-an-integration/learn-more/authentication/setting-up-oauth/) documentation.
## Add the Intercom connection
1. Select Integration Service from Automation Suite.
2. From the **Connectors** list, select Intercom. You can also use the search bar to find the connector.
3. Select the **Connect to Intercom** button.
4. Enter the required credentials.
5. Select **Connect**.
6. Next, you'll be prompted to log in to your Intercom account using your email and password.
7. After login, you must grant the Intercom connector access to your Intercom data. Refer to the **Permissions** section for details.
8. Your connection has been added.
## Permissions
The connector requires the following permissions:
* People - View and manage users and leads
* Companies - View and manage companies
* Conversations - View and update Inbox conversations
* Messages - View messages, campaigns and message insights
* Teams and teammates - View teams and teammates and set away status
* Intercom app capabilities - Access and receive data in Intercom apps
* Tags - View and manage people, company and conversation tags
* People activity - View and create people activity and events
* Workspace counts - View numerical counts of your workspace data
* Data attributes - Manage your customer and company attributes
* Tickets - View Manage tickets
* AI Content - View Manage AI Content.
