# About the Snowflake Cortex connector
> Integration Service connector for Snowflake Cortex in Automation Suite, providing agentic AI orchestration across structured and unstructured data sources using Cortex Analyst and Cortex Search.
Cortex Agents orchestrate across both structured and unstructured data sources to deliver insights. They plan tasks, use tools to execute these tasks, and generate responses.
Agents use Cortex Analyst (structured) and Cortex Search (unstructured) as tools, along with LLMs, to analyze data.
This integration is only available for workflows created in UiPath Maestro<sup>TM</sup>, using the **Start and Wait for External Agent** action.
:::note
This connector facilitates interactions with Cortex Agents. This feature is subject to a time limit, the final response from a Cortex Agent must arrive at UiPath within 90 seconds. This is a limitation of the current versions.
## Authentication
Before automating processes, you need to establish a connection with your Snowflake Cortex instance. Step-by-step instructions are available in the [Snowflake Cortex authentication](https://docs.uipath.com/integration-service/automation-suite/2.2510/user-guide/uipath-snowflake-cortex-authentication) page.
## Events
This connector does not currently support events.
## Activity package
You can use the connection to interact with a Snowflake Cortex agent in an agentic process. For a full list of supported activities, visit the [Snowflake Cortex activities](https://docs.uipath.com/activities/other/latest/integration-service/uipath-snowflake-cortex-about) page.
## Provider documentation
Find out more information about the Snowflake Cortex Agent API from the [Snowflake Cortex official API documentation](https://docs.snowflake.com/en/user-guide/snowflake-cortex/cortex-agents-rest-api).
