industry-department-solutions
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
Using Snowflake with Peak
Snowflake-specific behavior in Peak, including incremental load support, audit fields, case-sensitive SQL semantics, and schema management considerations.
This page summarizes how Peak behaves when your organization uses Snowflake as the data warehouse.
Feeds​
Snowflake supports incremental load only. When data is ingested, Peak appends audit fields such as peakauditcreatedate and feed-run-id.
SQL Explorer​
Snowflake uses case-sensitive SQL semantics. Unquoted identifiers are stored and resolved in uppercase. Use double quotes if you need to preserve lowercase identifiers.
Images and Workspaces​
When you build images for Workspaces, Workflows, or Web Apps, include Snowflake connectors, drivers, and connection parameters. Store credentials as environment variables prefixed with SNOWFLAKE_.
Dashboards​
Snowflake requires explicit column selection and consistent case handling. If a column name uses lowercase, wrap it in double quotes and define an alias. Avoid using * in queries when lowercase identifiers are used.
  • Feeds​
  • SQL Explorer​
  • Images and Workspaces​
  • Dashboards​
¿Necesita ayuda? Soporte
