industry-department-solutions
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
SKU calendar dataset
SKU calendar dataset containing active date ranges for products at locations, including discontinuation end dates, used by Inventory Management.
The SKU calendar dataset contains the active date ranges for products at locations, including discontinuation end dates. It defines when a product is available for sale at a given location.
Purpose​
The inventory management solution uses the SKU calendar dataset to understand when products are active at each location. This allows the solution to exclude periods when a product was not yet active or has been discontinued, improving the accuracy of demand analysis and recommendations.
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
product_idUnique identifier for the product.stringPrimary key
location_idUnique identifier for the location.stringPrimary key
start_dateDate the product becomes active at the location.dateNullable
end_dateDate the product is discontinued at the location. Required for discontinued products.dateNullable
Usage notes​
  • This dataset is optional and helps refine analysis by identifying active and discontinued periods.
  • Provide end_date for discontinued products so they can be excluded from forward-looking recommendations.
  • Product and location identifiers must align with the corresponding Products and Locations datasets.
  • Active date ranges should reflect actual product availability at each location.
  • Purpose​
  • Required fields​
  • Usage notes​
¿Necesita ayuda? Soporte
