industry-department-solutions
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
Sales dataset
Sales dataset containing completed transaction data per product-customer combination, used by Commercial Pricing to analyze how quoted prices translate into sales performance.
The Sales dataset contains completed transaction data for products sold to customers. It represents actual pricing outcomes and is used to evaluate how quoted and list prices translate into realized sales performance.
This dataset is required for application deployment and pricing insights analysis.
→ For the canonical technical schema (data types, validation rules, request/response examples), see Sale in the API Guide.
Purpose​
The commercial pricing solution uses the Sales dataset to:
  • Analyze actual transaction outcomes following quotes
  • Evaluate demand response to pricing decisions
  • Measure realized revenue and margin performance
  • Support win/loss and conversion analysis
Sales data complements the Quote Line dataset by providing actual transaction results rather than proposed prices.
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
sale_idUnique identifier for each sale.stringPrimary key
product_idUnique identifier for each product.stringPrimary key
region_idUnique identifier of the region.stringPrimary key
customer_idUnique identifier for each customer.stringNullable
merchant_idUnique identifier for each merchant.stringNullable
quote_idUnique identifier for each quote.stringNon-null
price_list_idPrice list used for this sale.stringNullable
sold_atTimestamp of sale.timestamp_tzPrimary key
quantityQuantity of the product sold.floatNullable
selling_priceSelling price for the product.floatNullable
Custom fields​
The fields listed previously are the standard schema for this dataset. A field that your business requires but the standard schema does not include can be added as a custom attribute after the schema is rolled out. Custom attributes are additive, so they extend the dataset without affecting existing fields, and they are validated in the same way as standard fields.
The following request adds a SALES_CHANNEL column to this dataset:
curl -X POST \
  'https://ingestion.peak.ai/api/v2/schema/QP_SALE_OOTB/add-attribute' \
  -d '{
    "solutionName": "QP_OOTB",
    "columnName": "SALES_CHANNEL",
    "dataType": "string",
    "validations": [
      { "type": "optional" }
curl -X POST \
  -d '{
    "validations": [
The table name in the request URL is this dataset's fully qualified warehouse name, which includes the prefix and suffix configured when your solution was rolled out — QP_SALE_OOTB in this example. Retrieve the name for your own solution with Describe a solution's schema.
On standard tables the API prefixes the new column name in the warehouse with C_ (Snowflake) or c_ (Redshift), so SALES_CHANNEL becomes C_SALES_CHANNEL and warehouse queries must use the prefixed name.
→ For the full parameter reference, supported data types, and validation rules, see Customizations in the API Guide.
Usage notes​
  • All referenced identifiers (product_id, customer_id, merchant_id, quote_id, region_id, price_list_id) must exist in their corresponding datasets.
  • Sales data should reflect finalized transactions, not quotes or provisional pricing.
  • Units of measure must be consistent with related datasets (Products, Quote Line).
  • Historical sales depth improves model stability and recommendation accuracy.
  • Consistency between Quote Line and Sales datasets supports reliable win/loss and conversion analysis.
Why this dataset matters​
The Sales dataset provides the outcome data necessary to evaluate the effectiveness of pricing decisions. Without actual transaction data, the solution cannot measure conversion performance, margin realization, or the true impact of pricing strategies.
  • Purpose​
  • Required fields​
  • Custom fields​
  • Usage notes​
  • Why this dataset matters​
¿Necesita ayuda? Soporte
