- Overview
- Platform setup and administration
- Platform architecture
- Data Bridge onboarding overview
- Connecting a Peak-managed data lake
- Connecting a customer-managed data lake
- Creating an AWS IAM role for Data Bridge
- Connecting a Snowflake data warehouse
- Connecting a Redshift data warehouse (public connectivity)
- Connecting a Redshift data warehouse (private connectivity)
- Reauthorizing a Snowflake OAuth connection
- Using Snowflake with Peak
- SQL Explorer overview
- Roles and permissions
- User management
- Inventory management solution
- Commercial pricing solution
- Merchandising solution
Purchase orders dataset
Purchase orders dataset containing details of supplier orders, used by Rebuy & Replenishment to project future inventory availability from inbound procurement.
The purchase orders dataset contains details of orders placed with external suppliers to replenish stock or raw materials, disaggregated by order number. It provides a history of purchase orders, including amendments, and is used by the Rebuy & Replenishment capability to project future inventory availability.
Purpose
The Rebuy & Replenishment capability uses the purchase orders dataset to:
- Account for stock on order when calculating inventory positions
- Generate stock parameters based on the total of on-hand stock and incoming supply
- Project future availability and support replenishment recommendations
By incorporating open and incoming purchase orders, the solution evaluates inventory exposure based on actual supply in transit, not just current on-hand stock.
Required fields
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
| Field | Description | Type | Constraint |
product_id | Unique identifier for the product SKU. | string | Non-null |
location_id | Unique identifier for the store or distribution centre. | string | Non-null |
order_number | Unique identifier for each purchase order. | string | Primary key |
source_id | Unique identifier for the supplier. | string | Non-null |
ordered_at | Date and time (UTC) when the purchase order was placed. | datetime | Non-null |
order_due_date | Date and time (UTC) when items on the purchase order are due to arrive. | datetime | Non-null |
ordered_units | Number of units ordered for the purchase order line item. | float | Non-null |
receipted_at | Date and time (UTC) when items on the purchase order were received. | datetime | Nullable |
receipted_units | Number of units received for the purchase order line item. | float | Nullable |
order_line_value | Cost price of units ordered for the purchase order line item. | float | Non-null |
order_line_status | Status of the purchase order line item (for example, Open, Pending approval, Closed). | string | Nullable |
Usage notes
- Purchase orders should be provided at line-item level to support accurate inventory projections.
- Both open and completed purchase orders should be included to preserve historical context.
- Partial receipts should be reflected using
receipted_unitsandreceipted_atfields alongside the original ordered quantities. - Identifiers (
product_id,location_id,source_id) must align with the corresponding Products, Locations, and Suppliers datasets. - Units of measure must be consistent across purchase orders, stock, and demand datasets.
