industry-department-solutions
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
Product extra dataset
Product extra dataset containing tenant-specific additional product attributes in key-value format, extending the standard Products dataset for Inventory Management.
The product extra dataset contains tenant-specific additional product attributes in key-value format. It allows custom product metadata to be provided beyond the standard Products dataset.
Purpose​
The inventory management solution uses the product extra dataset to capture custom product attributes that are specific to a tenant and not covered by the standard Products dataset. Each record stores a single attribute name and value for a product, allowing flexible extension of product metadata.
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
product_idUnique identifier for the product the attribute belongs to.stringPrimary key
product_extra_idUnique identifier for the extra attribute record.stringPrimary key
product_extra_attributeName of the custom attribute.stringNon-null
product_extra_valueValue of the custom attribute.stringNullable
created_atDate and time the record was created.datetimeNon-null
Usage notes​
  • This dataset is optional and only required when custom product attributes are needed beyond the standard Products dataset.
  • Each record represents a single attribute as a key-value pair, so a product can have multiple records.
  • Product identifiers must align with the corresponding Products dataset.
  • Attribute names should be used consistently across records to support reliable analysis.
  • Purpose​
  • Required fields​
  • Usage notes​
¿Necesita ayuda? Soporte
