industry-department-solutions
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
Platform setup and administration
Set up and administer the Peak platform for Supply Chain Solutions, including connecting data storage, configuring data ingestion, and managing access.
This chapter is for platform administrators and technical teams who set up Peak for Supply Chain Solutions. It explains how to connect data storage, configure data ingestion, and manage access.
If you are a business user, start with the solution chapters in this guide. If you are responsible for setup or integration, use the pages in this chapter.
How data flows in Peak​
Setting up Peak for Supply Chain Solutions follows this sequence:
  1. Connect your data storage — Use Data Bridge to connect your data warehouse (Snowflake or Redshift) and data lake (S3). This is required before any data can be ingested.
  2. Ingest your data — Use Data ingestion to configure connectors and feeds that pull data from external sources into your data warehouse on a schedule or on demand.
  3. Manage your files — Use Files to browse the data lake, organize files, and create file feeds directly from uploaded files.
  4. Query your data — Use SQL Explorer to run SQL queries against ingested data in your data warehouse.
What this chapter covers​
This chapter includes the following sections:
  • Data storage setup through Data Bridge
  • Data sources and data feeds
  • File storage ingestion options
  • File management in Peak
  • Access control and credentials
  • SQL Explorer basics
  • How data flows in Peak​
  • What this chapter covers​
¿Necesita ayuda? Soporte
