industry-department-solutions
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
Purchase orders dataset
Purchase orders dataset for the Markdown & Promotions module, tracking ordered, delivered, and receipted units per product and location.
The Purchase orders dataset tracks supplier orders, including ordered, delivered, and receipted units per product and location. It represents incoming supply used to project future availability.
Purpose​
The Markdown & Promotions module uses the Purchase orders dataset to:
  • Represent incoming supply from suppliers
  • Track order progress from placement through receipt
  • Support availability projections for markdown and promotion decisions
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
order_numberPurchase order number.stringPrimary key
product_idUnique identifier for the product SKU.stringPrimary key
Foreign key to product
actual_departure_atTimestamp when the order actually departed the supplier.timestampNullable
created_atTimestamp when the record was created.timestampNullable
delivered_unitsNumber of units delivered against the order.integerNullable
expected_departure_atTimestamp when the order was expected to depart the supplier.timestampNullable
location_idUnique identifier for the store or location.stringForeign key to location
Non-null
order_due_date_atDate the order is due to be received.timestampNon-null
ordered_atTimestamp when the order was placed.timestampNon-null
ordered_unitsNumber of units ordered.integerNon-null
purchase_order_idSource-system identifier for the purchase order.stringNullable
receipt_dateDate the order was received.dateNullable
receipted_unitsNumber of units receipted into stock.integerNullable
statusCurrent status of the purchase order.stringNullable
updated_atTimestamp when the record was last updated.timestampNullable
Usage notes​
  • Product and location identifiers must align with the Products and Locations datasets.
  • Units should use the same unit of measure as related datasets.
Why this dataset matters​
Incoming supply affects future availability, which informs whether products are candidates for clearance or promotion.
  • Purpose​
  • Required fields​
  • Usage notes​
  • Why this dataset matters​
¿Necesita ayuda? Soporte
