industry-department-solutions
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
Products dataset
Products dataset for the Markdown & Promotions module, containing the product reference metadata joined to sales, stock, pricing, and tax datasets.
The Products dataset contains metadata for the products managed by the Markdown & Promotions module. It defines the items included in analysis and provides the descriptive and categorical information used across markdown and promotion decisions.
This dataset acts as a reference dataset and is joined to other datasets, such as Sales, Stock, and Product pricing daily, using the product_id.
Purpose​
The Markdown & Promotions module uses the Products dataset to:
  • Identify the products included in markdown and promotion analysis
  • Enable analysis at both individual product and category levels
  • Ensure consistent product identifiers across all related datasets
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
product_idUnique identifier for the product SKU.stringPrimary key
created_atTimestamp when the record was created.timestampNullable
descriptionDescription of the product.stringNullable
lowest_product_category_idReference to the most specific (leaf) category the product belongs to.stringForeign key to product_category
Non-null
nameName of the product.stringNon-null
updated_atTimestamp when the record was last updated.timestampNullable
Usage notes​
  • Every product referenced in other datasets (for example, Sales, Stock, or Product pricing daily) must exist in the Products dataset.
  • The product_id must be consistent across all datasets.
  • Category information supports higher-level analysis and reporting.
Why this dataset matters​
The Products dataset defines the scope of the Markdown & Promotions module. Without a consistent product reference, the solution cannot reliably join sales, stock, and pricing data or generate meaningful recommendations.
  • Purpose​
  • Required fields​
  • Usage notes​
  • Why this dataset matters​
¿Necesita ayuda? Soporte
