industry-department-solutions
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
Product extra dataset
Product extra dataset for the Markdown & Promotions module, holding tenant-specific product attributes in key-value format.
The Product extra dataset holds tenant-specific product attributes in a key-value format, allowing additional descriptive data to be attached to products without changing the core Products dataset.
This dataset extends the Products dataset and is joined using the product_id.
Purpose​
The Markdown & Promotions module uses the Product extra dataset to:
  • Attach custom, tenant-specific attributes to products
  • Support segmentation and analysis using attributes not in the core Products dataset
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
product_extra_attributeName of the custom product attribute.stringPrimary key
product_extra_valueValue of the custom product attribute.stringPrimary key
product_idUnique identifier for the product SKU.stringPrimary key
Foreign key to product
created_atTimestamp when the record was created.timestampNullable
updated_atTimestamp when the record was last updated.timestampNullable
Usage notes​
  • Each row represents a single attribute-value pair for a product.
  • The product_id must reference an existing product in the Products dataset.
Why this dataset matters​
Custom attributes let the solution incorporate business-specific product characteristics into markdown and promotion analysis.
  • Purpose​
  • Required fields​
  • Usage notes​
  • Why this dataset matters​
¿Necesita ayuda? Soporte
