industry-department-solutions
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
Locations dataset
Locations dataset for the Markdown & Promotions module, defining the stores or locations where products are sold and stocked.
The Locations dataset defines the stores or locations where products are sold, stocked, and priced. It provides the geographic and currency context used across the Markdown & Promotions module.
This dataset acts as a reference dataset and is joined to other datasets, such as Sales, Stock, and Product pricing daily, using the location_id.
Purpose​
The Markdown & Promotions module uses the Locations dataset to:
  • Define where products are sold and stocked
  • Enable analysis across stores, regions, and channels
  • Provide the currency context for value-based metrics
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
location_idUnique identifier for the store or location.stringPrimary key
countryCountry in which the location operates.stringNon-null
created_atTimestamp when the record was created.timestampNullable
updated_atTimestamp when the record was last updated.timestampNullable
nameName of the location.stringNullable
regionRegion used to segment locations for analysis.stringNullable
currencyCurrency used at the location.stringNullable
Usage notes​
  • Every location referenced in other datasets must exist in the Locations dataset.
  • The location_id must be consistent across all datasets.
Why this dataset matters​
Location context lets the solution analyse markdown and promotion performance by store, region, or channel, and normalise values across currencies.
  • Purpose​
  • Required fields​
  • Usage notes​
  • Why this dataset matters​
¿Necesita ayuda? Soporte
