industry-department-solutions
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
Currency conversion dataset
Currency conversion dataset for the Markdown & Promotions module, providing exchange rates between currency pairs for cross-region value normalisation.
The Currency conversion dataset provides exchange rates between currency pairs. It is used to normalise monetary values across regions that trade in different currencies.
This dataset acts as a reference dataset, providing exchange rates used to normalise values across regions.
Purpose​
The Markdown & Promotions module uses the Currency conversion dataset to:
  • Provide exchange rates between currency pairs
  • Normalise values across regions for consistent analysis
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
from_currencyCurrency to convert from.stringPrimary key
to_currencyCurrency to convert to.stringPrimary key
exchange_rateExchange rate used to convert from the source to the target currency.floatNon-null
updated_atTimestamp when the record was last updated.timestampNullable
created_atTimestamp when the record was created.timestampPrimary key
Usage notes​
  • Provide a rate for each currency pair used across the Locations dataset.
  • Rates should be kept current to support accurate value normalisation.
Why this dataset matters​
Consistent currency conversion lets the solution compare and aggregate values across regions that trade in different currencies.
  • Purpose​
  • Required fields​
  • Usage notes​
  • Why this dataset matters​
¿Necesita ayuda? Soporte
