industry-department-solutions
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
Locations dataset
Locations dataset containing metadata for stores, distribution centres, and other inventory sites used by the Inventory Management solution.
The locations dataset contains metadata for the locations used by the inventory management solution. Locations typically represent stores, distribution centres, or other sites where inventory is stored, replenished, or planned.
This dataset provides contextual information about where inventory exists and how locations function within the supply chain.
Purpose​
The solution uses the locations dataset to:
  • Identify where inventory is held or replenished
  • Distinguish between different types of locations, such as stores and distribution centres
  • Support analysis and reporting across the supply network
During analysis, location metadata helps the solution correctly interpret inventory flows and planning behavior across the network.
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
location_idUnique identifier for the location.stringPrimary key
location_nameName of the location.stringNullable
countryCountry where the location is based.stringNullable
is_storeIndicates whether the location is a store.booleanNon-null
is_dcIndicates whether the location is a distribution centre.booleanNon-null
is_factoryIndicates whether the location is a manufacturing facility.booleanNon-null
Usage notes​
  • Every location referenced in other datasets (for example, Stock, Customer orders, Purchase orders, or Transfers) must exist in the locations dataset.
  • Location identifiers must be consistent across all datasets.
  • The is_store, is_dc, and is_factory flags help distinguish how locations are treated in planning and analysis.
  • If additional location attributes are required for specific use cases, they can be incorporated during onboarding.
  • Purpose​
  • Required fields​
  • Usage notes​
¿Necesita ayuda? Soporte
