industry-department-solutions
Supply Chain & Retail Solutions release notes
  • Inventory management solution release notes
    • 2026
      • October 2026
      • September 2026
      • August 2026
      • July 2026
      • June 2026
      • May 2026
      • April 2026
  • Commercial pricing solution release notes
  • Merchandising solution release notes
  • Rebuy & replenishment solution release notes
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
May 2026
May 2026 release notes for Inventory Management.
May 8, 2026​
Data Ingestion API v2​
The Supply Chain & Retail Data Ingestion API has been updated to v2. The new version introduces schema management, a built-in monitoring dashboard, and more flexible ingestion modes.
  • Schema lifecycle management — save a standard schema per application version, roll it out to a tenant solution (automatically creates warehouse tables and a _failed_rows companion table for each), upgrade to a new schema version with additive-only changes, or add individual columns without a full version upgrade.
  • Data Quality Dashboard — a pre-built canvas asset that monitors ingestion outcomes in real time: KPI cards for records ingested and pass/fail/warning counts, time-series charts, top error codes, per-table and per-request breakdowns, and a failed-rows detail page showing the exact source field values that failed validation.
  • Scheduled ingestion — opt-in per table and tenant; rows buffer as they arrive and flush to the warehouse on a configured cron schedule. Both Quartz and Unix cron formats are supported.
  • Async validation by default — validation runs asynchronously after the API responds; failed rows are written to the _failed_rows companion tables and surfaced in the Data Quality Dashboard.
  • dryRun flag — all schema and ingest endpoints accept dryRun: true to validate a payload without persisting it.
  • 207 Multi-Status partial-success — rollouts and upgrades return 207 when some tables succeed and some fail, with successfulObjects and failedObjects maps in the response.
Learn more​
  • May 8, 2026​
  • Data Ingestion API v2​
¿Necesita ayuda? Soporte
