industry-department-solutions
Supply Chain & Retail Solutions release notes
  • Inventory management solution release notes
    • 2026
      • October 2026
      • September 2026
      • August 2026
      • July 2026
      • June 2026
      • May 2026
      • April 2026
  • Commercial pricing solution release notes
  • Merchandising solution release notes
  • Rebuy & replenishment solution release notes
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
June 2026
June 2026 release notes for Inventory Management.
June 15, 2026​
Optional columns in standard schemas​
Standard-schema columns can now be declared optional. Each column's validations must include exactly one of { "type": "required" } or { "type": "optional" }: a required column's key must be present in every ingest payload, while an optional column can be omitted and is stored as NULL (or its defaultValue).
Primary-key columns must stay required, and nonNull may only be combined with required. Applies to the save-schema, add-column, and custom-table endpoints. See Schema lifecycle.
Data Quality Dashboard redesign​
The Data Quality Dashboard has been rebuilt as a single scrolling overview page with a table-level drill-down. It now opens with a Monitoring filters bar (start date, end date, solution) and a Current health snapshot of five KPI cards — total requests, rows processed, validation failures, rows ingested, and pass rate — each with period-over-period comparisons. Below that are three trend charts (error-code trend, validation results over time, and pass rate over time), a ranked Top error codes table, searchable Breakdown by table and Breakdown by request views, and a Current slice summary. Selecting a table opens a detail view scoped to that table, solution, and date range.
June 3, 2026​
New: Integration walkthrough​
A new Integration walkthrough page in the API Guide walks customer IT teams, solution engineers, and support engineers through the four stages of integrating with the Data Ingestion API: extract, transform, align field names, and batch + send. Each stage has the relevant API calls embedded inline — GET /api/v2/schema/solutions to confirm what's rolled out, POST /api/v2/objects/{objectName} for ingesting batches (with a dryRun variant), and POST /api/v2/schema/{objectName}/add-attribute for adding tenant-specific columns — alongside Snowflake COPY INTO and Redshift UNLOAD recipes for the extract step. Designed as a single one-stop guide rather than scattered references.
Bulk-ingest guide: folder-load sort order spelled out​
The Historical data ingestion guide's "File or folder?" section now spells out the folder-load sort-order rules. Lexicographic sort gives the right order when filenames encode order as zero-padded numbers (part-0001.csv) or ISO-style date prefixes (2024-06-01.csv) — both forms warehouse exports produce by default. It gives the wrong order for non-padded part numbers, DD-MM-YYYY or MM-DD-YYYY date names, or month-name files like January_report.csv. The doc now lists each failure case in a comparison table and recommends the safe naming pattern.
June 2, 2026​
Historical data ingestion guide​
A new guide covers loading large historical datasets (millions to billions of rows) into the Data Ingestion API. It explains the design considerations for at-scale loads — streaming, dynamic batching, rate-limiting, foreign-key ordering, checkpointing, and failed-row handling — and provides a self-contained Python reference script you can configure and run. See Historical data ingestion.
Bulk-ingest script​
The Python reference script in the historical-data-ingestion guide:
  • Loads one table per run with a minimal CONFIG block (csv_path, object_name, solution_name, operation_type, parallel). To load several tables, run the script once per table.
  • Accepts a folder of CSV part-files as the source, in addition to a single CSV file. Chunked exports are loaded in sorted filename order.
  • Reads gzip-compressed CSVs transparently, detected from the .gz extension.
  • Recognises both empty string (Redshift UNLOAD default) and \N (Snowflake COPY INTO default) as null markers.
  • Fails fast if a CSV row has more cells than the header, instead of silently shifting data into the wrong columns.
  • Tolerates uncastable cells (e.g. "abc" in an integer column) by passing them through to the API as raw strings, so one bad cell becomes one rejected row, not a stopped load.
  • Exposes a parallel toggle for UPSERT loads where a primary key can appear more than once in the source.
The guide also includes warehouse-specific UNLOAD / COPY INTO recipes for Snowflake and Redshift, and a section on re-running the script (resume behaviour, where checkpoint and failed-row files live, how to start fresh).
Operation type guidance​
The API guide now frames the choice between APPEND and UPSERT around what the downstream solution needs from the data — current state vs full history — rather than around data type.
Add-column endpoint: nullability guidance​
The Add a new column section now has a Controlling required-ness and nullability on the new column subsection. It documents that required and nonNull are independent validators in the add-column path and lays out the four valid combinations as a small table:
  • Key required + value non-null
  • Key required + value nullable
  • Key optional + value non-null
  • Key optional + value nullable
The subsection also calls out the API-enforced mutual exclusion of defaultValue and nonNull — sending both returns 400 Bad Request with the exact error message the API produces ("Cannot use 'nonNull' validation with defaultValue. defaultValue ensures the field always has a value."), so customers can match the failure in their integration logs.
These guarantees apply equally to the Inventory Management solution; the doc clarification is shared across all Supply Chain & Retail solutions that use the Data Ingestion API.
¿Necesita ayuda? Soporte
