industry-department-solutions
Supply Chain & Retail Solutions release notes
  • Inventory management solution release notes
    • 2026
      • October 2026
      • September 2026
      • August 2026
      • July 2026
      • June 2026
      • May 2026
      • April 2026
  • Commercial pricing solution release notes
  • Merchandising solution release notes
  • Rebuy & replenishment solution release notes
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
August 2026
August 2026 release notes for Inventory Management in Automation Cloud.
August 26, 2026​
New: alerts for failing object-level validations​
A failing object-level validation can now notify a Slack channel or an email group, so a data quality problem reaches your team without anyone watching the dashboard. Alert channels can be registered once per tenant through /api/v2/alert-configs and named in a new alerts array on a freshness or missing_data_validation entry. The reserved name __ALL__ notifies every channel registered for the tenant.
Alerts are sent only when a check finishes in a failed or error state, and the run report lists the channels notified for each result in alerts_sent. A channel that cannot be reached does not fail the validation run. See Data quality alerts.
August 12, 2026​
Renamed: add-object replaces custom-table​
The endpoint for adding a custom object to a solution is now POST /api/v2/schema/add-object, replacing POST /api/v2/schema/custom-table. The new name pairs with POST /api/v2/schema/{objectName}/add-attribute — one adds a table, the other adds a column. Request and response bodies are unchanged, and the previous custom-table path continues to work, though it is deprecated and may be removed in a future release; add-object is the recommended alternative going forward. See Add a custom object.
Corrected: primaryKeys is required when adding a custom object​
The Add a custom object payload reference previously listed primaryKeys as optional. It has always been required — a request without a non-empty primaryKeys array is rejected with 400 Bad Request, and every name in it must match a column declared in columns.
August 10, 2026​
Bulk CSV upload​
You can now ingest a large dataset by uploading a CSV (or .csv.gz) file directly to an existing table, instead of sending rows as JSON. Uploads are scanned for malware, validated against the schema per row, and processed asynchronously — poll the returned requestId for status and success/failure counts. See Bulk CSV upload.
Object validations in the Data Quality Dashboard​
The Data Quality Dashboard now surfaces object-level validation results alongside the existing row-level metrics — freshness age vs. threshold, missing-data gaps, and per-period shortfall, with per-table drill-down. See Object-level validations.
¿Necesita ayuda? Soporte
