industry-department-solutions
- Overview
- API Resources
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
SKU Calendar
SKU Calendar API resource defining the active date range for a product-location combination, controlling which SKUs are included in replenishment planning.
The SKU Calendar resource defines the active date range during which a product-location combination (SKU) is considered live and eligible for replenishment planning. Each record specifies a start and end date for the SKU's activity window, enabling the system to include or exclude specific product-location pairs from planning runs based on their lifecycle status.
Resource Endpoint
/api/v2/ingest/object/{prefix}SKU_CALENDAR{suffix}
Supported Methods
| Method | Return Type | Description |
| POST | Response | Ingest (create/update) SKU Calendar records via UPSERT operation |
Request Headers
| Header | Required | Description |
Authorization | Yes | Your Personal Access Token (PAT) from platform.peak.ai |
Content-Type | Yes | Must be application/json |
Properties
Primary Keys
- product_id (string) - Unique identifier for the product. Part of the composite primary key.
- location_id (string) - Unique identifier for the location. Part of the composite primary key.
Attributes
| Attribute | Data Type | Required | Description |
product_id | string | Yes | Unique identifier for the product |
location_id | string | Yes | Unique identifier for the location |
start_date | date | No | The date from which the SKU is considered active at this location, in YYYY-MM-DD format |
end_date | date | No | The date on which the SKU becomes inactive at this location, in YYYY-MM-DD format |
Relationships
Outbound References
The sku_calendar resource does not reference any downstream resources as foreign keys.
Inbound References
The following resources are referenced by sku_calendar:
- products —
product_id→products.product_id - locations —
location_id→locations.location_id
JSON Representation
"solutionName": "INV_OOTB",
"data": [
"product_id": "PROD-001",
"location_id": "LOC-001",
"start_date": "2025-01-01",
"end_date": "2025-12-31"
"operationType": "UPSERT"
"data": [
Example Request
curl -X POST \
'https://ingestion.peak.ai/api/v2/objects/INV_SKU_CALENDAR_OOTB' \
-d '{
"data": [
curl -X POST \
-d '{
"data": [
Important Notes
product_idandlocation_idtogether form the composite primary key. Both fields must be provided on every record.start_dateandend_dateare optional. When omitted, the SKU is assumed to be permanently active or the activity window is managed externally.- Dates must be provided in
YYYY-MM-DDformat. Timestamps must be inYYYY-MM-DD HH:MM:SSformat. product_idmust correspond to an existing record in the Products resource.location_idmust correspond to an existing record in the Locations resource.- Records are ingested via UPSERT: an existing record with matching primary keys will be updated; otherwise a new record is inserted.
