industry-department-solutions
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
Suppliers
Suppliers API resource representing external vendors in the procurement process, including minimum order quantities and values for inventory planning.
Overview​
The Suppliers resource represents the external vendors and supply sources used in the procurement process. Each record captures a supplier's identity and the ordering constraints they impose, such as minimum order quantities and minimum order values. Suppliers are referenced by other resources as the source_id field to establish supply relationships.
Resource Endpoint​
/api/v2/ingest/object/{prefix}SUPPLIERS{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) Suppliers records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • supplier_id (string) - Unique identifier for the supplier. Used as the primary key for deduplication and UPSERT operations.
Attributes​
AttributeData TypeRequiredDescription
supplier_idstringYesUnique identifier for the supplier
supplier_namestringYesHuman-readable name of the supplier
minimum_order_quantityintegerNoThe minimum number of units that must be ordered from this supplier
moq_unit_of_measurestringNoThe unit of measure applicable to the minimum order quantity (for example, "units", "cases")
minimum_order_valueintegerNoThe minimum monetary value that must be met per order from this supplier
mov_unit_of_measurestringNoThe currency or unit applicable to the minimum order value (for example, "GBP", "USD")
Relationships​
Outbound References​
The suppliers resource does not reference any other resource as a foreign key.
Inbound References​
The following resources reference suppliers via source_id:
  • order_parameters — source_id → suppliers.supplier_id
  • purchase_orders — source_id → suppliers.supplier_id
  • transfers — source_id → suppliers.supplier_id
JSON Representation​
  "solutionName": "INV_OOTB",
  "data": [
      "supplier_id": "SUP-001",
      "supplier_name": "Global Parts Ltd",
      "minimum_order_quantity": 100,
      "moq_unit_of_measure": "units",
      "minimum_order_value": 500,
      "mov_unit_of_measure": "GBP"
  "operationType": "UPSERT"
  "data": [
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/INV_SUPPLIERS_OOTB' \
  -d '{
    "data": [
curl -X POST \
  -d '{
    "data": [
Important Notes​
  • supplier_id is the primary key, used for deduplication and UPSERT operations.
  • The supplier_id value is used as the source_id field in related resources such as Purchase Orders, Order Parameters, and Transfers.
  • minimum_order_quantity and minimum_order_value are optional. When omitted, the system assumes no minimum constraints apply.
  • Ensure moq_unit_of_measure and mov_unit_of_measure are populated when their corresponding minimum values are provided.
¿Necesita ayuda? Soporte
