industry-department-solutions
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
SKU Calendar
SKU Calendar API resource defining the active date range for a product-location combination, controlling which SKUs are included in replenishment planning.
Overview​
The SKU Calendar resource defines the active date range during which a product-location combination (SKU) is considered live and eligible for replenishment planning. Each record specifies a start and end date for the SKU's activity window, enabling the system to include or exclude specific product-location pairs from planning runs based on their lifecycle status.
Resource Endpoint​
/api/v2/ingest/object/{prefix}SKU_CALENDAR{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) SKU Calendar records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • product_id (string) - Unique identifier for the product. Part of the composite primary key.
  • location_id (string) - Unique identifier for the location. Part of the composite primary key.
Attributes​
AttributeData TypeRequiredDescription
product_idstringYesUnique identifier for the product
location_idstringYesUnique identifier for the location
start_datedateNoThe date from which the SKU is considered active at this location, in YYYY-MM-DD format
end_datedateNoThe date on which the SKU becomes inactive at this location, in YYYY-MM-DD format
Relationships​
Outbound References​
The sku_calendar resource does not reference any downstream resources as foreign keys.
Inbound References​
The following resources are referenced by sku_calendar:
  • products — product_id → products.product_id
  • locations — location_id → locations.location_id
JSON Representation​
  "solutionName": "INV_OOTB",
  "data": [
      "product_id": "PROD-001",
      "location_id": "LOC-001",
      "start_date": "2025-01-01",
      "end_date": "2025-12-31"
  "operationType": "UPSERT"
  "data": [
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/INV_SKU_CALENDAR_OOTB' \
  -d '{
    "data": [
curl -X POST \
  -d '{
    "data": [
Important Notes​
  • product_id and location_id together form the composite primary key. Both fields must be provided on every record.
  • start_date and end_date are optional. When omitted, the SKU is assumed to be permanently active or the activity window is managed externally.
  • Dates must be provided in YYYY-MM-DD format.
  • product_id must correspond to an existing record in the Products resource.
  • location_id must correspond to an existing record in the Locations resource.
  • Records are ingested via UPSERT: an existing record with matching primary keys will be updated; otherwise a new record is inserted.
¿Necesita ayuda? Soporte
