industry-department-solutions
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
Sales
Sales API resource representing daily sales actuals per product-location combination, providing the historical demand signal for the inventory optimization engine.
Overview​
The Sales resource represents daily sales actuals for a product at a specific location. Each record captures the number of units sold and the total monetary value of those sales on a given day, providing the historical demand signal used by the inventory optimisation engine for forecasting and replenishment planning.
Resource Endpoint​
/api/v2/ingest/object/{prefix}SALES_DAILY{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) Sales records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • product_id (string) - Unique identifier for the product. Part of the composite primary key.
  • location_id (string) - Unique identifier for the location. Part of the composite primary key.
  • day_date (date) - The calendar date for which sales are recorded. Part of the composite primary key.
Attributes​
AttributeData TypeRequiredDescription
product_idstringYesUnique identifier for the product sold
location_idstringYesUnique identifier for the location at which sales occurred
day_datedateYesThe date of the sales record, in YYYY-MM-DD format
sales_unitsfloatYesNumber of units sold on the given date
sales_valuefloatYesTotal monetary value of units sold on the given date
Relationships​
Outbound References​
The sales_daily resource does not reference any downstream resources as foreign keys.
Inbound References​
The following resources are referenced by sales_daily:
  • products — product_id → products.product_id
  • locations — location_id → locations.location_id
JSON Representation​
  "solutionName": "INV_OOTB",
  "data": [
      "product_id": "PROD-001",
      "location_id": "LOC-001",
      "day_date": "2025-01-15",
      "sales_units": 42.0,
      "sales_value": 1049.58
  "operationType": "UPSERT"
  "data": [
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/INV_SALES_DAILY_OOTB' \
  -d '{
    "data": [
curl -X POST \
  -d '{
    "data": [
Important Notes​
  • product_id, location_id, and day_date together form the composite primary key. All three fields must be provided on every record.
  • day_date must be in YYYY-MM-DD format.
  • sales_units must be a non-negative number. A value of 0 is valid and indicates no sales occurred on that date.
  • sales_value must be a non-negative float representing the total revenue value for the day.
  • product_id must correspond to an existing record in the Products resource.
  • location_id must correspond to an existing record in the Locations resource.
  • Records are ingested via UPSERT: an existing record with matching primary keys will be updated; otherwise a new record is inserted.
¿Necesita ayuda? Soporte
