industry-department-solutions
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
Purchase Orders
Purchase Orders API resource representing outbound procurement orders placed with external suppliers, tracking order lines from placement through receipt.
Overview​
The Purchase Orders resource represents outbound procurement orders placed with external suppliers. Each record tracks a single order line for a product at a location, capturing the full order lifecycle from placement through to receipt, including quantities, financial value, and current status.
Resource Endpoint​
/api/v2/ingest/object/{prefix}PURCHASE_ORDERS{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) Purchase Orders records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • order_number (string) - Unique identifier for the purchase order. Used as the primary key for deduplication and UPSERT operations.
Attributes​
AttributeData TypeRequiredDescription
order_numberstringYesUnique identifier for the purchase order line
product_idstringYesUnique identifier for the product being ordered
location_idstringYesUnique identifier for the destination location
source_idstringYesIdentifier of the supplier fulfilling this order
ordered_attimestampYesDatetime when the order was placed
order_due_datetimestampYesExpected delivery date for the order
ordered_unitsintegerYesNumber of units ordered
receipted_attimestampNoDatetime when the order was received
receipted_unitsintegerNoNumber of units actually received
order_line_valuefloatYesTotal monetary value of the order line
order_line_statusstringNoCurrent status of the order line (for example, "open", "in_transit", "received")
Relationships​
Outbound References​
The purchase_orders resource does not reference any downstream resources as foreign keys.
Inbound References​
The following resources are referenced by purchase_orders:
  • products — product_id → products.product_id
  • locations — location_id → locations.location_id
JSON Representation​
  "solutionName": "INV_OOTB",
  "data": [
      "order_number": "PO-2025-001",
      "product_id": "PROD-001",
      "location_id": "LOC-001",
      "source_id": "SUP-001",
      "ordered_at": "2025-01-10 09:00:00",
      "order_due_date": "2025-01-24 00:00:00",
      "ordered_units": 200,
      "receipted_at": "2025-01-23 14:30:00",
      "receipted_units": 198,
      "order_line_value": 2500.00,
      "order_line_status": "received"
  "operationType": "UPSERT"
  "data": [
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/INV_PURCHASE_ORDERS_OOTB' \
  -d '{
    "data": [
curl -X POST \
  -d '{
    "data": [
Important Notes​
  • order_number is the primary key, used for deduplication and UPSERT operations.
  • source_id should correspond to a valid supplier_id in the Suppliers resource.
  • receipted_at and receipted_units are optional and should be populated once the goods have been physically received.
  • order_line_value should reflect the total value of the order line in the relevant currency.
  • All timestamps must be provided in YYYY-MM-DD HH:MM:SS format.
  • Records are ingested via UPSERT: subsequent updates to the same order_number will overwrite the existing record.
¿Necesita ayuda? Soporte
