industry-department-solutions
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
Products Parent Child Mapping
Products Parent Child Mapping API resource defining parent-child relationships between products for substitution and hierarchy modelling in the Rebuy & Replenishment model.
Overview​
The Products Parent Child Mapping resource defines parent-child relationships between products. Each record links a child product to its parent, along with a label and rank that describe the child's role within the hierarchy. This mapping supports substitution and product hierarchy modelling in the Rebuy & Replenishment model.
Resource Endpoint​
/api/v2/ingest/object/{prefix}PRODUCTS_PARENT_CHILD_MAPPING{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) Products Parent Child Mapping records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • child_id (string) - Unique identifier for the child product. Used as the primary key for deduplication and UPSERT operations.
Attributes​
AttributeData TypeRequiredDescription
parent_idstringYesUnique identifier of the parent product in the hierarchy
child_idstringYesUnique identifier of the child product mapped to the parent
child_labelstringYesHuman-readable label describing the child product's role or variant
child_rankintegerYesOrdering rank of the child within the parent's hierarchy
Relationships​
Outbound References​
The products_parent_child_mapping resource does not reference any downstream resources as foreign keys.
Inbound References​
The following resources are referenced by products_parent_child_mapping:
  • products — parent_id → products.product_id
  • products — child_id → products.product_id
JSON Representation​
  "solutionName": "INV_OOTB",
  "data": [
      "parent_id": "PROD-001",
      "child_id": "PROD-002",
      "child_label": "Small",
      "child_rank": 1
  "operationType": "UPSERT"
  "data": [
      "child_rank": 1
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/INV_PRODUCTS_PARENT_CHILD_MAPPING_OOTB' \
  -d '{
    "data": [
        "child_rank": 1
curl -X POST \
  -d '{
    "data": [
        "child_rank": 1
Important Notes​
  • child_id is the primary key, used for deduplication and UPSERT operations. Each child product maps to exactly one parent.
  • parent_id and child_id must both correspond to existing records in the Products resource.
  • child_rank orders sibling children under the same parent; lower ranks are typically presented first.
  • Records are ingested via UPSERT: an existing record with matching primary keys will be updated; otherwise a new record is inserted.
¿Necesita ayuda? Soporte
