industry-department-solutions
- Overview
- API Resources
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
Products
Products API resource for the Rebuy & Replenishment capability of the Merchandising solution, representing the item catalogue with identity, categorization, packaging, and supplier reference.
The Products resource represents the catalogue of items managed within the inventory system. Each product record captures the item's identity, categorisation, packaging details, and source supplier reference. Products are the central entity in the data model, referenced by nearly every other resource.
Resource Endpoint
/api/v2/ingest/object/{prefix}PRODUCTS{suffix}
Supported Methods
| Method | Return Type | Description |
| POST | Response | Ingest (create/update) Products records via UPSERT operation |
Request Headers
| Header | Required | Description |
Authorization | Yes | Your Personal Access Token (PAT) from platform.peak.ai |
Content-Type | Yes | Must be application/json |
Properties
Primary Keys
- product_id (string) - Unique identifier for the product. Used as the primary key for deduplication and UPSERT operations.
Attributes
| Attribute | Data Type | Required | Description |
product_id | string | Yes | Unique identifier for the product |
product_name | string | No | Human-readable name of the product |
product_description | string | No | Detailed description of the product |
product_category | string | No | Category or classification of the product |
source_id | string | Yes | Identifier of the primary supplier or source for this product |
pack_size | integer | Yes | Number of individual units contained within a single pack |
minimum_order_quantity | integer | No | Minimum number of units that can be ordered at one time |
product_image_urls | string | No | URL or comma-separated list of URLs pointing to product images |
Relationships
Outbound References
The products resource does not reference any other resource as a foreign key.
Inbound References
The following resources reference products via product_id:
- stock_daily —
product_id→products.product_id - pricing —
product_id→products.product_id - order_parameters —
product_id→products.product_id - purchase_orders —
product_id→products.product_id - transfers —
product_id→products.product_id - sku_calendar —
product_id→products.product_id - sales_daily —
product_id→products.product_id - product_extra —
product_id→products.product_id - products_parent_child_mapping —
parent_id→products.product_idandchild_id→products.product_id
JSON Representation
"solutionName": "INV_OOTB",
"data": [
"product_id": "PROD-001",
"product_name": "Blue Widget",
"product_description": "A sturdy blue widget",
"product_category": "Widgets",
"source_id": "SUP-001",
"pack_size": 12,
"minimum_order_quantity": 24,
"product_image_urls": "https://example.com/img/prod001.jpg"
"operationType": "UPSERT"
"data": [
"pack_size": 12,
Example Request
curl -X POST \
'https://ingestion.peak.ai/api/v2/objects/INV_PRODUCTS_OOTB' \
-d '{
"data": [
"pack_size": 12,
curl -X POST \
-d '{
"data": [
"pack_size": 12,
Important Notes
product_idis the primary key, used for deduplication and UPSERT operations.source_idshould match a validsupplier_idin the Suppliers resource to maintain referential integrity.pack_sizeis required and must be a positive integer representing the number of sellable units per pack.- Records are ingested via UPSERT: an existing record with matching primary keys will be updated; otherwise a new record is inserted.
