industry-department-solutions
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
Pricing
Pricing API resource representing cost and list price information per product-location combination over optional validity windows.
Overview​
The Pricing resource represents cost and list price information for a product at a specific location. Each record defines the unit cost price and unit list price applicable over an optional validity window, allowing the system to maintain historical and future pricing data for accurate inventory valuation and order planning.
Resource Endpoint​
/api/v2/ingest/object/{prefix}PRICING{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) Pricing records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • product_id (string) - Unique identifier for the product. Part of the composite primary key.
  • location_id (string) - Unique identifier for the location. Part of the composite primary key.
  • created_at (timestamp) - Timestamp when the pricing record was created. Part of the composite primary key.
Attributes​
AttributeData TypeRequiredDescription
product_idstringYesUnique identifier for the product
location_idstringYesUnique identifier for the location
unit_cost_pricefloatYesThe cost price per unit for the product at this location
unit_list_pricefloatYesThe list (retail or transfer) price per unit for the product at this location
valid_fromtimestampNoThe datetime from which this pricing record becomes effective
valid_totimestampNoThe datetime at which this pricing record expires
created_attimestampYesThe datetime this pricing record was created
Relationships​
Outbound References​
The pricing resource does not reference any downstream resources as foreign keys.
Inbound References​
The following resources are referenced by pricing:
  • products — product_id → products.product_id
  • locations — location_id → locations.location_id
JSON Representation​
  "solutionName": "INV_OOTB",
  "data": [
      "product_id": "PROD-001",
      "location_id": "LOC-001",
      "unit_cost_price": 12.50,
      "unit_list_price": 24.99,
      "valid_from": "2025-01-01 00:00:00",
      "valid_to": "2025-12-31 23:59:59",
      "created_at": "2025-01-15 08:00:00"
  "operationType": "UPSERT"
  "data": [
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/INV_PRICING_OOTB' \
  -d '{
    "data": [
curl -X POST \
  -d '{
    "data": [
Important Notes​
  • product_id, location_id, and created_at together form the composite primary key. All three fields must be provided on every record.
  • All timestamps must be provided in YYYY-MM-DD HH:MM:SS format.
  • unit_cost_price and unit_list_price must be non-negative float values.
  • valid_from and valid_to are optional; omitting them implies the pricing record has no bounded validity window.
  • Multiple pricing records can exist for the same product-location combination to represent different validity periods.
  • product_id must correspond to an existing record in the Products resource.
  • location_id must correspond to an existing record in the Locations resource.
¿Necesita ayuda? Soporte
