industry-department-solutions
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
Product
product API resource for the B2B pricing application, with categorization and bespoke product indicators used in quote pricing scenarios.
Overview​
The product resource represents product entities in the B2B pricing application. This resource stores product information including categorization and bespoke product indicators.
→ For business context (purpose, usage notes, how this resource is used in the solution), see Products dataset in the User Guide.
Resource Endpoint​
/api/v2/ingest/object/{prefix}PRODUCT{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) product records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • product_id (string) - Unique identifier for the product
  • updated_at (datetime) - Timestamp of when the record was last updated
Attributes​
About Required + Nullable: every attribute key must appear in each payload (Required: Yes). Nullable: Yes means the value can be null when you don't have data; Nullable: No means a non-null value is required. See Schema definition structure for the underlying rules.
AttributeData TypeRequiredNullableDescription
product_idstringYesNoUnique identifier for each product. Used to join product metadata to quotations and sales for model training.
updated_atdatetimeYesYesTimestamp when the record was updated. Used to identify the most up-to-date data in the UI and to match product metadata to the date of each quote in model training.
product_namestringYesNoProduct name. Used in the UI to identify products.
bespoke_productbooleanYesYesWhether the product is bespoke (custom-made) or standard. Used in model training as a feature to determine the optimal quote price.
product_categorystringYesYesProduct category. Used in model training as a feature to determine the optimal quote price.
product_subcategorystringYesYesProduct sub-category. Used in model training as a feature to determine the optimal quote price.
Relationships​
Outbound References​
This resource has relationships to:
  • competitor_price - Products can have competitive pricing data
  • list_price - Products can have list prices across regions
  • product_cost - Products can have cost information
  • quote_line - Products can appear in quote line items
  • sale - Products can be sold
Inbound References​
None
JSON Representation​
  "solutionName": "QP_OOTB",
  "data": [
      "product_id": "PROD-001",
      "updated_at": "2025-01-28T10:00:00Z",
      "product_name": "Premium Widget",
      "bespoke_product": false,
      "product_category": "Electronics",
      "product_subcategory": "Components"
  "operationType": "UPSERT"
  "data": [
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/QP_PRODUCT_OOTB' \
  -d '{
    "data": [
curl -X POST \
  -d '{
    "data": [
Important Notes​
  • Bespoke Products: The bespoke_product flag can be used to identify custom or made-to-order products
  • Custom Attributes: Custom attributes can be added with POST /api/v2/schema/{objectName}/add-attribute, where {objectName} is this table's fully qualified warehouse name ({prefix}PRODUCT{suffix} — for example, QP_PRODUCT_OOTB), as returned by Describe a solution's schema
  • Data Validation: All attributes are validated according to their defined data types
¿Necesita ayuda? Soporte
