industry-department-solutions
- Overview
- API Resources
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
Product Extra
product_extra API resource for storing additional dynamic attributes on B2C pricing application products as flexible key-value pairs.
The product_extra resource represents additional dynamic attributes for products in the B2C pricing application. This resource enables flexible key-value pairs for product-specific metadata.
Resource Endpoint
/api/v2/ingest/object/{prefix}PRODUCT_EXTRA{suffix}
Supported Methods
| Method | Return Type | Description |
| POST | Response | Ingest (create/update) product extra records via UPSERT operation |
Request Headers
| Header | Required | Description |
Authorization | Yes | Your Personal Access Token (PAT) from platform.peak.ai |
Content-Type | Yes | Must be application/json |
Properties
Primary Keys
- product_extra_attribute (string) - Name of the extra attribute
- product_extra_value (string) - Value of the extra attribute
- product_id (string) - Foreign key reference to products
Attributes
About Required + Nullable: every attribute key must appear in each payload (Required: Yes). Nullable: Yes means the value can be null when you don't have data; Nullable: No means a non-null value is required. See Schema definition structure for the underlying rules.
| Attribute | Data Type | Required | Nullable | Description |
product_extra_attribute | string | Yes | No | Attribute name (Primary Key) |
product_extra_value | string | Yes | No | Attribute value (Primary Key) |
product_id | string | Yes | No | Product identifier (Primary Key, Foreign Key) |
created_at | timestamp | Yes | Yes | Timestamp when the record was created |
updated_at | timestamp | Yes | Yes | Timestamp when the record was last updated |
Relationships
Outbound References
None
Inbound References
- product - Foreign key
product_idreferences product
JSON Representation
"solutionName": "MP_OOTB",
"data": [
"product_extra_attribute": "color",
"product_extra_value": "black",
"product_id": "PROD-001",
"created_at": "2025-01-10T08:00:00Z",
"updated_at": "2025-01-28T10:00:00Z"
"operationType": "UPSERT"
"data": [
Example Request
curl -X POST \
'https://ingestion.peak.ai/api/v2/objects/MP_PRODUCT_EXTRA_OOTB' \
-d '{
"data": [
"product_extra_attribute": "size",
"product_extra_value": "medium",
curl -X POST \
-d '{
"data": [
Important Notes
- Foreign Key Dependencies: Requires valid
product_idto exist in the products object - Flexible Schema: Enables storing variable product attributes without schema changes
- Multiple Attributes: A single product can have many extra attributes
- Use Cases: Ideal for variant attributes (color, size), specifications, or custom metadata
- Custom Attributes: Additional custom attributes can be added using the
/PRODUCT_EXTRA/add-attributeendpoint - Data Validation: All attributes are validated according to their defined data types
Related Resources
- product - Base product information
