industry-department-solutions
- Overview
- API Resources
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
Product Extra
Product Extra API resource for storing custom key-value attributes against an Inventory Management product, enabling schema extensibility without core changes.
The Product Extra resource provides a flexible mechanism for storing additional, custom attributes against a product that are not captured in the core Products schema. Each record represents a single key-value attribute pair for a product, enabling extensibility without schema changes.
Resource Endpoint
/api/v2/ingest/object/{prefix}PRODUCT_EXTRA{suffix}
Supported Methods
| Method | Return Type | Description |
| POST | Response | Ingest (create/update) Product Extra records via UPSERT operation |
Request Headers
| Header | Required | Description |
Authorization | Yes | Your Personal Access Token (PAT) from platform.peak.ai |
Content-Type | Yes | Must be application/json |
Properties
Primary Keys
- product_id (string) - Unique identifier for the product this attribute belongs to. Part of the composite primary key.
- product_extra_id (string) - Unique identifier for this specific extra attribute record. Part of the composite primary key.
Attributes
| Attribute | Data Type | Required | Description |
product_id | string | Yes | Unique identifier for the product this attribute belongs to |
product_extra_id | string | Yes | Unique identifier for this extra attribute record |
product_extra_attribute | string | Yes | The name of the custom attribute (for example, "weight_kg", "colour") |
product_extra_value | string | No | The value of the custom attribute (for example, "2.5", "blue") |
created_at | timestamp | Yes | Timestamp when this extra attribute record was first created |
Relationships
Outbound References
The product_extra resource does not reference any downstream resources as foreign keys.
Inbound References
The following resource is referenced by product_extra:
- products —
product_id→products.product_id
JSON Representation
"solutionName": "INV_OOTB",
"data": [
"product_id": "PROD-001",
"product_extra_id": "ATTR-001",
"product_extra_attribute": "weight_kg",
"product_extra_value": "2.5",
"created_at": "2025-01-10 08:00:00"
"operationType": "UPSERT"
"data": [
Example Request
curl -X POST \
'https://ingestion.peak.ai/api/v2/objects/INV_PRODUCT_EXTRA_OOTB' \
-d '{
"data": [
curl -X POST \
-d '{
"data": [
Important Notes
product_idandproduct_extra_idtogether form the composite primary key. Both fields must be provided on every record.product_extra_attributeis required and defines the name of the custom attribute being stored.product_extra_valueis optional; it may be omitted or set tonullif no value is currently available for the attribute.- All attribute values are stored as strings, regardless of the underlying data type they represent.
product_idmust correspond to an existing record in the Products resource.- All timestamps must be provided in
YYYY-MM-DD HH:MM:SSformat.
