industry-department-solutions
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
Historical data ingestion
Load large volumes of historical data into the v2 Supply Chain & Retail Solutions Data Ingestion API.
This page describes how to load large volumes of historical data (millions to billions of rows) into the v2 Data Ingestion API. It provides a reference Python script that loads every table in your solution in a single run and handles streaming, batching, rate limiting, retries, and resume — along with the warehouse-specific configuration you'll need to give it.
Scope. This script is for one-shot historical loads — a single, possibly multi-hour load performed once during onboarding. For ongoing incremental data after that initial load, post new rows directly to POST /api/v2/objects/{objectName} using the contracts in the API Guide. The script's checkpoint is a crash-recovery aid within a single load, not a state machine across separate runs over time.
For everyday low-volume ingestion, the API contracts described in Getting Started and the API Guide are sufficient. Use this page when you have a one-time bulk load to perform.
If you'd rather hand the platform a CSV file than run a script, see Bulk CSV upload — it uploads one file per table and processes it server-side, without the streaming, checkpointing, and resume this script provides.
Before you start​
  • Your solution's tables have been rolled out (see Schema lifecycle).
  • You have a Personal Access Token (see Getting Started).
  • Each table you're loading is available as CSV — either a single file, or a folder of CSV part-files (as produced by chunked warehouse exports).
  • Every CSV file includes a header row, and the column names match the rolled-out schema (case-insensitive). When the source is a folder, every file in it must share the same header.
  • You know whether your tenant is on the hub (https://ingestion.peak.ai) or on a spoke cluster (https://ingestion.<cluster-identifier>.peak.ai — for example https://ingestion.peaksydney.peak.ai). Your account manager provides the cluster identifier for your tenant. See the warning below.
Warning:
Spoke tenants must set base_url to their spoke host before running the script. The script defaults base_url to the hub host https://ingestion.peak.ai. A spoke tenant that leaves the default can violate the tenant's data-residency requirements.
Source file format​
The script reads CSV files. Headers are required — every CSV file must include a header row with the column names from the rolled-out schema (case-insensitive). The script matches columns by name, so the order of columns in your SELECT doesn't matter and there's no risk of accidentally writing quoted_price values into the discount_pct column. If csv_path is a folder of part-files, every file in it must share the same header.
Beyond headers, two things about your unload can vary, and the script handles both:
  • File naming pattern — set file_glob in CONFIG when csv_path is a folder (default *.csv).
  • Gzip compression — auto-detected from the .gz extension; no flag needed.
File or folder?​
csv_path accepts either form:
  • A file path — e.g. ./customers.csv. file_glob is ignored.
  • A folder path — e.g. ./customers/. Every file in the folder matching file_glob is loaded as if it were one logical CSV. Use this for chunked warehouse exports.
Folder-load file order. When csv_path is a folder, files are loaded in lexicographic (byte-by-byte ASCII) order of their filenames. This is the right order when the names already encode order as zero-padded numeric or ISO-style date prefixes — the form that warehouse exports produce by default.
FilenamesLexicographic orderRight?
part-0001.csv, part-0002.csv, …, part-9999.csvpart-0001, part-0002, …, part-9999✓ matches numeric order
2024-01-15.csv, 2024-02-10.csv, 2024-06-01.csv2024-01-15, 2024-02-10, 2024-06-01✓ matches chronological order
part-1.csv, part-2.csv, …, part-10.csvpart-1, part-10, part-2, …✗ 10 sorts before 2 (not zero-padded)
15-01-2023.csv, 10-02-2024.csv, 01-06-2024.csv (DD-MM-YYYY)01-06-2024, 10-02-2024, 15-01-2023✗ day-first puts June 2024 before Jan 2023
01-15-2023.csv, 02-10-2024.csv, 06-01-2024.csv (MM-DD-YYYY)01-15-2023, 02-10-2024, 06-01-2024✗ year is last, so 2023 and 2024 interleave
January_report.csv, February_report.csv, March_report.csvFebruary, January, March✗ alphabetical, not chronological
If file order doesn't matter (every file is an independent batch and rows have no cross-file dependency), this isn't a concern. If file order does matter — for example, you're using APPEND and the row sequence is meaningful, or UPSERT and later files supersede earlier ones — make sure your filenames sort lexicographically into the order you intend. The safe pattern is a zero-padded numeric or ISO-date prefix (e.g., part-0001.csv, 2024-06-01.csv); rename or re-export if your source uses something else.
Fully qualified object_name​
object_name must be the exact table name as rolled out — including any prefix or suffix that was applied at rollout. For example, if your rollout applied a prefix acme_ and suffix _v1, the configured object_name is acme_customers_v1, not customers. If your rollout supplied neither a prefix nor a suffix, object_name is just the table name itself (e.g., customers).
To look up the exact value for any table, call GET /api/v2/schema?solutionName=<your-solution> and read the objectName field for each entry — that's the exact string to use in object_name.
From Snowflake​
Snowflake COPY INTO @stage defaults to no headers, gzip compression, and \N as the null marker. Add HEADER = TRUE so columns match by name, and NULL_IF = ('') so nulls are written as empty strings instead of \N. (The script handles either marker, but empty strings give a cleaner CSV.)
COPY INTO @your_stage/orders/
FROM (SELECT custcode, addcode, postcode, streetcode, basketvalue FROM orders)
FILE_FORMAT = (TYPE = CSV HEADER = TRUE NULL_IF = (''));
Once the unloaded files are downloaded locally, add an entry to CONFIG["tables"] with csv_path set to that folder. Use "*.csv" for file_glob instead if you disabled gzip with COMPRESSION = NONE:
{"object_name": "acme_orders_v1", "csv_path": "./orders/", "file_glob": "*.csv.gz"},
From Redshift​
Redshift UNLOAD defaults to no headers, no compression, and no file extension on the part-files. Add HEADER so columns match by name, and EXTENSION 'csv' so files are easy to glob:
UNLOAD ('SELECT custcode, addcode, postcode, streetcode, basketvalue FROM orders')
TO 's3://your-bucket/orders/'
HEADER
FORMAT CSV
EXTENSION 'csv';
HEADER
FORMAT CSV
EXTENSION 'csv';
Once the unloaded files are downloaded locally, add an entry to CONFIG["tables"] with csv_path set to that folder. "*.csv" is the default file_glob; use "*" if you kept Redshift's extensionless part-files, or "*.gz" if you enabled GZIP:
{"object_name": "acme_orders_v1", "csv_path": "./orders/", "file_glob": "*.csv"},
Null values and bad cells​
The script treats a cell as null when, after trimming whitespace, it matches one of these markers (case-insensitively): an empty string, \N (the Redshift UNLOAD and Snowflake COPY INTO defaults), NULL, NA, or N/A. This covers the null representations found in most real-world warehouse exports.
Warning:
NA and N/A are treated as null. That's convenient for most data, but wrong if a column can legitimately hold those strings — for example, NA is Namibia's ISO country code, and N/A is a valid category label in some datasets. If any column in your load can contain them as real values, edit the NULL_MARKERS set near the top of the script and remove the entries you don't want — whatever you remove is then sent through as that exact string.
The full set of null markers lives in one place so you can adjust it:
NULL_MARKERS = {"", "\\N", "NULL", "NA", "N/A"}
Uncastable cells are passed through as raw strings rather than crashing the load. If "abc" lands in an integer column, the API returns that single row as a failed row with the appropriate error code (see Validation behavior for the failed-row response shape) — one bad cell becomes one rejected row, not a stopped load.
Character encoding​
Customer exports aren't always UTF-8. Before reading each file the script detects its encoding, trying utf-8-sig (UTF-8, with any byte-order mark stripped), then cp1252 (common for Windows-generated files), then latin-1 as a catch-all that decodes any byte sequence.
When a file is decoded as anything other than utf-8-sig, the script logs which encoding it fell back to, so you can spot a mojibake risk early. No configuration is needed.
Run modes and options​
Behavior is controlled with command-line flags — you don't edit the CONFIG block to switch modes:
FlagEffect
--mode historicalDefault. APPEND operation, batches sent in parallel.
--mode dailyUPSERT operation, batches sent serially (one at a time, in order). For smaller recurring reloads.
--table OBJECT_NAMELoad only this one table from CONFIG["tables"] instead of all of them.
--dry-runParse, validate, and batch every table but send nothing to the API.
--archiveAfter each table loads successfully, move its source files into archive/<date>/<table>/.
--mode historical (APPEND, parallel)​
For a one-time bulk load, historical mode is the right choice — APPEND is significantly faster than UPSERT when you don't need update-by-primary-key semantics, and parallel workers maximise throughput.
One thing to note about APPEND: if a batch partially succeeds and you re-send the same batch, the rows that already landed will fail with a duplicate-primary-key error. The script's checkpointing handles this for you — a successful batch is never re-sent on a subsequent run.
--mode daily (UPSERT, serial)​
Daily mode uses UPSERT, for recurring incremental reloads where the same primary key can reappear and later rows should supersede earlier ones. Batches are sent serially — one at a time, in order — so the last write for a key wins deterministically. (Parallel workers finish in unpredictable order, so a parallel UPSERT of duplicated keys could leave either version in the warehouse; serial avoids that.)
--dry-run​
A dry run streams, parses, casts, and batches every table exactly as a real load would — surfacing malformed CSVs, too-wide rows, and encoding problems — but sends nothing and writes no checkpoint or failed-row files. It logs the row and batch count each table would produce.
Use it to validate a fresh set of exports before committing to a multi-hour load. (It still reads your schema, so it needs the token and network access; it makes no writes.)
Loading multiple tables​
The script loads every table in CONFIG["tables"] in a single run — you don't invoke it once per table. List one entry per table:
"tables": [
    {"object_name": "acme_products_v1",    "csv_path": "./products/"},
    {"object_name": "acme_order_items_v1",  "csv_path": "./order_items/"},
"tables": [
List order is load order — put parent tables before their children (foreign-key dependency order). In the example above, if order_items references orders and orders references products, listing them products → orders → order_items loads them in the right order.
Loading them out of order causes foreign-key violations in the asynchronous validation stage. Tables load sequentially (one finishes before the next starts); batches within a table run in parallel in historical mode.
To load a single table from the list — for a re-run, or to load them one at a time — pass --table <object_name>.
Reference script​
The script is self-contained — paste it into a single Python file, edit the CONFIG block at the top, and run it. It requires only the requests library (pip install requests).
#!/usr/bin/env python3
Bulk-ingest historical CSV data into the Peak Data Ingestion v2 API.
- One run loads every table in CONFIG["tables"], in list order.
- Streams each source row-by-row (no full in-memory load).
- Dynamically sizes batches to <=2000 rows AND <=1 MB serialized.
- Concurrent workers share a token-bucket rate limiter.
- Exponential backoff on 5xx / 429; never retries 4xx.
- Checkpoint lets multi-hour runs resume cleanly after a crash.
- Failed rows written to a JSONL log and a consolidated JSON report.
- Run mode, single-table, dry-run, and archive are chosen with CLI flags.
from __future__ import annotations
import argparse
import csv
import gzip
import json
import logging
import os
import shutil
import threading
import time
from concurrent.futures import ThreadPoolExecutor, as_completed
from dataclasses import dataclass
from datetime import datetime
from pathlib import Path
from typing import Any, Iterable
import requests
CONFIG: dict[str, Any] = {
    "base_url":      "https://ingestion.peak.ai",
    "auth_token":    os.environ["PEAK_AUTH_TOKEN"],
    "solution_name": "your-solution-name",
    "tables": [
        {"object_name": "acme_customers_v1", "csv_path": "./customers.csv"},
MAX_ROWS_PER_BATCH = 2000
MAX_BYTES_PER_BATCH = 1_048_576
RATE_LIMIT_RPS = 30
WORKERS = 6
MAX_RETRIES = 5
INITIAL_BACKOFF_SECONDS = 1.0
REQUEST_TIMEOUT_SECONDS = 60
CHECKPOINT_DIR = "./checkpoints"
FAILED_ROWS_DIR = "./failed_rows"
ARCHIVE_DIR = "./archive"
MODES = {
    "historical": {"operation_type": "APPEND", "parallel": True},
    "daily":      {"operation_type": "UPSERT", "parallel": False},
_NULL_MARKERS_LOWER = {m.lower() for m in NULL_MARKERS}
ENCODINGS = ("utf-8-sig", "cp1252", "latin-1")
logging.basicConfig(level=logging.INFO, format="%(asctime)s %(levelname)s %(message)s")
log = logging.getLogger("bulk_ingest")
@dataclass
class Run:
    """Everything a single load run needs beyond the per-table config."""
    base_url: str
    auth_token: str
    solution_name: str
    operation_type: str
    workers: int
    dry_run: bool
    archive: bool
    rate_limiter: "RateLimiter"
class RateLimiter:
    def __init__(self, rps: int) -> None:
        self.rps = rps
        self.tokens = float(rps)
        self.last_refill = time.monotonic()
        self.lock = threading.Lock()
    def acquire(self) -> None:
        while True:
            with self.lock:
                now = time.monotonic()
                self.tokens = min(self.rps, self.tokens + (now - self.last_refill) * self.rps)
                self.last_refill = now
                if self.tokens >= 1:
                    self.tokens -= 1
                    return
                wait = (1 - self.tokens) / self.rps
            time.sleep(wait)
def fetch_schema_types(base_url: str, auth_token: str, solution_name: str) -> dict[str, dict[str, str]]:
    url = f"{base_url}/api/v2/schema"
    headers = {"Authorization": auth_token}
    resp = requests.get(url, params={"solutionName": solution_name}, headers=headers, timeout=30)
    resp.raise_for_status()
    schema = resp.json()
    type_map: dict[str, dict[str, str]] = {}
    for table in schema.get("schema", []):
        name = table["objectName"].upper()
        type_map[name] = {
            col["columnName"]: col.get("dataType") or col.get("peakDataType") or "string"
            for col in table.get("columns", [])
    return type_map
_CASTERS = {
    "integer": int,
    "numeric": float,
    "float": float,
    "boolean": lambda s: s.lower() in ("true", "1", "t", "yes", "y"),
    "json": json.loads,
def cast_value(value: str, data_type: str) -> Any:
    if value is None:
        return None
    stripped = value.strip()
    if stripped.lower() in _NULL_MARKERS_LOWER:
        return None
    caster = _CASTERS.get((data_type or "string").lower())
    return caster(stripped) if caster else value
def cast_row(row: dict[str, str], column_types: dict[str, str]) -> dict[str, Any]:
    """Cast each cell to its schema type.
    If a cell cannot be cast (for example, "abc" in an integer column), the raw
    string is passed through unchanged. The API will then surface it as a
    structured failed-row error with the right code, rather than the worker
    thread crashing.
    out: dict[str, Any] = {}
    for col, raw in row.items():
        try:
            out[col] = cast_value(raw, column_types.get(col, "string"))
        except (ValueError, TypeError, json.JSONDecodeError):
            out[col] = raw
    return out
def resolve_csv_paths(csv_path: str, file_glob: str = "*.csv") -> list[str]:
    p = Path(csv_path)
    if p.is_dir():
        files = sorted(str(f) for f in p.glob(file_glob))
        if not files:
            raise FileNotFoundError(f"no files matching '{file_glob}' in folder: {csv_path}")
        return files
    return [csv_path]
def detect_encoding(csv_path: str) -> str:
    opener = gzip.open if csv_path.endswith(".gz") else open
    for enc in ENCODINGS:
        try:
            with opener(csv_path, "rt", encoding=enc, newline="") as f:
                for _ in f:
                    pass
            return enc
        except UnicodeDecodeError:
            continue
    return ENCODINGS[-1]
def iter_batches(
    csv_paths: list[str],
    column_types: dict[str, str],
    max_rows: int,
    max_bytes: int,
) -> Iterable[list[dict[str, Any]]]:
    batch: list[dict[str, Any]] = []
    batch_bytes = 0
    for csv_path in csv_paths:
        encoding = detect_encoding(csv_path)
        if encoding != ENCODINGS[0]:
            log.info("%s: decoded as %s (not %s)", csv_path, encoding, ENCODINGS[0])
        with opener(csv_path, "rt", newline="", encoding=encoding) as f:
            reader = csv.DictReader(f)
            for raw_row in reader:
                if None in raw_row:
                    extras = raw_row[None]
                    raise RuntimeError(
                        f"{csv_path}: row has more columns than the header. "
                        f"Extra cells: {extras!r}. "
                        f"Check that every row matches the header width."
                row = cast_row(raw_row, column_types)
                row_bytes = len(json.dumps(row, default=str).encode("utf-8"))
                if batch and (len(batch) >= max_rows or batch_bytes + row_bytes >= max_bytes):
                    yield batch
                    batch, batch_bytes = [], 0
                batch.append(row)
                batch_bytes += row_bytes
    if batch:
        yield batch
def ingest_batch(run: Run, object_name: str, batch: list[dict[str, Any]]) -> dict[str, Any]:
    url = f"{run.base_url}/api/v2/objects/{object_name}"
    headers = {
        "Authorization": run.auth_token,
        "Content-Type": "application/json",
        "accept": "application/json",
    body = {"solutionName": run.solution_name, "data": batch, "operationType": run.operation_type}
    backoff = INITIAL_BACKOFF_SECONDS
    for attempt in range(1, MAX_RETRIES + 1):
        run.rate_limiter.acquire()
        try:
            resp = requests.post(url, headers=headers, json=body, timeout=REQUEST_TIMEOUT_SECONDS)
        except requests.RequestException as exc:
            if attempt == MAX_RETRIES:
                raise
            log.warning("network error: %s; retry in %.1fs", exc, backoff)
            time.sleep(backoff)
            backoff *= 2
            continue
        if resp.status_code in (200, 207, 400):
            return resp.json()
        if resp.status_code == 429 or 500 <= resp.status_code < 600:
                raise RuntimeError(f"max retries reached ({resp.status_code}): {resp.text[:200]}")
            log.warning("status %s; retry in %.1fs (attempt %d/%d)", resp.status_code, backoff, attempt, MAX_RETRIES)
            time.sleep(backoff)
            backoff *= 2
            continue
        raise RuntimeError(f"{resp.status_code}: {resp.text[:200]}")
    raise RuntimeError("unreachable")
def write_failed_report(failed_jsonl: Path, report_path: Path) -> int:
    rows = [json.loads(line) for line in failed_jsonl.read_text().splitlines() if line.strip()]
    report_path.write_text(json.dumps(rows, indent=2, default=str))
    return len(rows)
def archive_source(csv_paths: list[str], object_name: str) -> Path:
    stamp = datetime.now().strftime("%Y-%m-%d")
    dest = Path(ARCHIVE_DIR) / stamp / object_name
    dest.mkdir(parents=True, exist_ok=True)
    for path in csv_paths:
        shutil.move(path, str(dest / Path(path).name))
    return dest
def load_table(run: Run, table: dict[str, Any], type_map: dict[str, dict[str, str]]) -> None:
    object_name = table["object_name"]
    file_glob = table.get("file_glob", "*.csv")
    csv_paths = resolve_csv_paths(table["csv_path"], file_glob)
    log.info("[%s] %d source file(s), glob=%s", object_name, len(csv_paths), file_glob)
    column_types = type_map.get(object_name.upper(), {})
    if not column_types:
        log.warning("[%s] no schema columns found; values pass through as strings", object_name)
    if run.dry_run:
        rows = batches = 0
        for batch in iter_batches(csv_paths, column_types, MAX_ROWS_PER_BATCH, MAX_BYTES_PER_BATCH):
            batches += 1
            rows += len(batch)
        log.info("[%s] DRY RUN: %d rows would be sent in %d batches — nothing written", object_name, rows, batches)
        return
    Path(CHECKPOINT_DIR).mkdir(parents=True, exist_ok=True)
    Path(FAILED_ROWS_DIR).mkdir(parents=True, exist_ok=True)
    ckpt_path = Path(CHECKPOINT_DIR) / f"{object_name}.json"
    failed_path = Path(FAILED_ROWS_DIR) / f"{object_name}.jsonl"
    next_batch = 0
    if ckpt_path.exists():
        next_batch = json.loads(ckpt_path.read_text()).get("next_batch", 0)
        if next_batch > 0:
            log.info("[%s] resuming from batch #%d", object_name, next_batch)
    pending = [
        (i, b) for i, b in enumerate(
        ) if i >= next_batch
    if not pending:
        log.info("[%s] already complete", object_name)
        if run.archive:
            log.info("[%s] archived to %s", object_name, archive_source(csv_paths, object_name))
        return
    log.info("[%s] %d batches remaining", object_name, len(pending))
    total_ok = total_failed = 0
    ckpt_lock = threading.Lock()
    completed: set[int] = set()
    to_persist = next_batch
    def submit(idx_batch):
        idx, batch = idx_batch
        return idx, ingest_batch(run, object_name, batch)
    with ThreadPoolExecutor(max_workers=run.workers) as pool:
        futures = {pool.submit(submit, ib): ib for ib in pending}
        for fut in as_completed(futures):
            idx, result = fut.result()
            ok = result.get("successRows", 0)
            failed = result.get("failedRows", 0)
            total_ok += ok
            total_failed += failed
            if result.get("failed"):
                with failed_path.open("a") as f:
                    for row in result["failed"]:
                        f.write(json.dumps({"batch": idx, **row}) + "\n")
            with ckpt_lock:
                completed.add(idx)
                while to_persist in completed:
                    completed.remove(to_persist)
                    to_persist += 1
                ckpt_path.write_text(json.dumps({"next_batch": to_persist}))
            log.info(
                "[%s] batch #%d: %d ok / %d failed (running: %d ok / %d failed)",
                object_name, idx, ok, failed, total_ok, total_failed,
    if failed_path.exists():
        report_path = Path(FAILED_ROWS_DIR) / f"{object_name}_failed.json"
        count = write_failed_report(failed_path, report_path)
        log.info("[%s] %d failed row(s) written to %s", object_name, count, report_path)
    log.info("[%s] complete: %d rows ingested, %d failed", object_name, total_ok, total_failed)
    if run.archive:
def parse_args() -> argparse.Namespace:
    parser = argparse.ArgumentParser(description="Bulk-load historical CSV data into the Peak Data Ingestion v2 API.")
    parser.add_argument(
        "--mode", choices=sorted(MODES), default="historical",
        help="historical = APPEND + parallel (default); daily = UPSERT + serial.",
        "--table", metavar="OBJECT_NAME",
        help="Load only this table from CONFIG['tables']. Default: load them all, in order.",
        "--dry-run", action="store_true",
        help="Parse, validate and batch every table but send nothing to the API.",
        "--archive", action="store_true",
        help="After a table loads successfully, move its source files into archive/<date>/<table>/.",
    return parser.parse_args()
def main() -> None:
    args = parse_args()
    cfg = CONFIG
    mode = MODES[args.mode]
    tables = cfg["tables"]
    if args.table:
        tables = [t for t in tables if t["object_name"] == args.table]
        if not tables:
            names = ", ".join(t["object_name"] for t in cfg["tables"])
            raise SystemExit(f"--table {args.table!r} not found in CONFIG['tables'] (have: {names})")
    log.info("Fetching schema column types for solution %s", cfg["solution_name"])
    type_map = fetch_schema_types(cfg["base_url"], cfg["auth_token"], cfg["solution_name"])
    log.info("Schema fetched: %d tables", len(type_map))
    workers = WORKERS if mode["parallel"] else 1
    run = Run(
        base_url=cfg["base_url"],
        auth_token=cfg["auth_token"],
        solution_name=cfg["solution_name"],
        operation_type=mode["operation_type"],
        workers=workers,
        dry_run=args.dry_run,
        archive=args.archive,
        rate_limiter=RateLimiter(RATE_LIMIT_RPS),
    log.info(
        "Mode: %s (%s, %s)%s",
        args.mode,
        run.operation_type,
        f"{workers} workers" if workers > 1 else "serial — batches applied in order",
        " [DRY RUN]" if run.dry_run else "",
    for table in tables:
        log.info("=" * 70)
        log.info("Loading %s from %s", table["object_name"], table["csv_path"])
        log.info("=" * 70)
        load_table(run, table, type_map)
    log.info("Done.")
if __name__ == "__main__":
    main()
import argparse
import csv
import gzip
import json
import logging
import os
import shutil
import threading
import time
import requests
    "tables": [
RATE_LIMIT_RPS = 30
WORKERS = 6
MAX_RETRIES = 5
MODES = {
@dataclass
class Run:
    base_url: str
    auth_token: str
    solution_name: str
    operation_type: str
    workers: int
    dry_run: bool
    archive: bool
class RateLimiter:
        self.rps = rps
        while True:
            with self.lock:
                    self.tokens -= 1
                    return
            time.sleep(wait)
        type_map[name] = {
    return type_map
_CASTERS = {
    "integer": int,
    "numeric": float,
    "float": float,
    "json": json.loads,
    if value is None:
        return None
        return None
    thread crashing.
        try:
            out[col] = raw
    return out
    p = Path(csv_path)
    if p.is_dir():
        if not files:
        return files
    return [csv_path]
        try:
                for _ in f:
                    pass
            return enc
            continue
def iter_batches(
    max_rows: int,
    max_bytes: int,
    batch_bytes = 0
                if None in raw_row:
                    raise RuntimeError(
                    yield batch
                batch.append(row)
    if batch:
        yield batch
    headers = {
        try:
                raise
            time.sleep(backoff)
            backoff *= 2
            continue
            return resp.json()
            time.sleep(backoff)
            backoff *= 2
            continue
    return len(rows)
    return dest
    if run.dry_run:
        rows = batches = 0
            batches += 1
            rows += len(batch)
        return
    next_batch = 0
        if next_batch > 0:
    pending = [
    if not pending:
        if run.archive:
        return
            total_ok += ok
            with ckpt_lock:
                completed.add(idx)
                    to_persist += 1
            log.info(
    if run.archive:
def main() -> None:
    args = parse_args()
    cfg = CONFIG
    if args.table:
        if not tables:
    run = Run(
        workers=workers,
    log.info(
        args.mode,
        run.operation_type,
        log.info("=" * 70)
        log.info("=" * 70)
    log.info("Done.")
    main()
Running the script​
  1. Save the script as bulk_ingest.py.
  2. Install the dependency: pip install requests.
  3. Export your Personal Access Token: export PEAK_AUTH_TOKEN=....
  4. Edit the CONFIG block:
    • Set solution_name and the tables list (one entry per table, in foreign-key dependency order).
    • Set file_glob on an entry if that table's source is a folder with non-default file names.
    • If your tenant is on a spoke cluster, set base_url to your spoke host (https://ingestion.<cluster-identifier>.peak.ai) — see the spoke base-URL warning above.
  5. Validate first with a dry run: python bulk_ingest.py --dry-run.
  6. Run it: python bulk_ingest.py (add --mode daily, --table <name>, or --archive as needed — see Run modes and options).
Result​
The script logs progress per batch, table by table. You can stop it (Ctrl-C) and resume it later — it picks up from the last successfully-persisted batch index.
Rows the API rejects during the load are captured two ways, per table, in the failed_rows/ directory:
  • failed_rows/<table>.jsonl — the durable, crash-safe log, appended one line per rejected row as the load runs.
  • failed_rows/<table>_failed.json — a consolidated JSON array written when the table finishes, for quickly eyeballing everything that failed and why.
Asynchronous validation failures (foreign-key violations, primary-key collisions against pre-existing data) don't appear in either file — they show up in the Data Quality Dashboard instead.
With --archive, each table's source files are moved into archive/<date>/<table>/ once it loads successfully, leaving you an empty source folder to drop the next batch of files into and a dated record of what was already ingested. (Re-running an archived table reports "no files matching" — that's expected; its files have moved.)
Resuming after a crash​
If the script stops mid-load — a network blip, a laptop reboot, anything — just run it again and it picks up from where it left off. No rows are re-sent and none are dropped.
Two files persist between runs to make that work:
  • checkpoints/<table>.json — tracks how far the load got, so the script knows where to resume.
  • failed_rows/<table>.jsonl — appended to each time the API rejects a row.
On resume, the script reads the checkpoint, skips the batches it already completed, and continues from there. You'll see [<table>] resuming from batch #N in the logs at startup.
If you want a clean restart — for example, you've truncated the warehouse table and want to load from scratch — delete the state files first. Replace <table> with the object_name from your CONFIG (e.g., acme_customers_v1):
rm checkpoints/<table>.json failed_rows/<table>.jsonl failed_rows/<table>_failed.json
Or wipe all tables' state at once if you're re-loading several:
rm -rf checkpoints failed_rows
Editing the source CSV between runs is not supported. The checkpoint tracks batch indices, not row content — so if you add or modify rows in the source file and re-run, the changes can be silently skipped. For example, adding one row to a CSV that previously fit in a single batch leaves the new row in batch #0, which the checkpoint marks "skip." If you need to add or modify rows after a load has completed, post them directly to POST /api/v2/objects/{objectName} rather than re-running the script with the edited file.
Tips for multi-day runs​
  • Run from a stable host. A laptop that sleeps or moves between networks will interrupt the run; the script will resume cleanly, but you'll lose elapsed time. If you're running on a remote host over SSH, use nohup or a terminal multiplexer (tmux, screen) so the script survives the session dropping.
  • Monitor disk space. Failed-row files grow with the volume of validation failures. For a dataset with 1% failure rate across 100M rows, that's 1M JSONL entries.
  • Investigate sustained errors early. If you see persistent 5xx responses or sudden throughput drops, stop the run and submit a support ticket before exhausting retries. A dataset of this size is easier to debug at hour 2 than at hour 20.
  • Treat the failed-row files as a second-pass workload. After the bulk load completes, fix the data issues surfaced in the failed_rows/ directory and re-submit those rows in a smaller load. Read <table>_failed.json to triage what went wrong; each entry captures the row as the API saw it — extract the row payload, fix the offending field(s), and submit a small batch via POST /api/v2/objects/{objectName} directly (see the API Guide for the request shape).
  • Watch for encoding fallbacks. If the logs show a file being decoded as cp1252 or latin-1 rather than UTF-8, spot-check a few rows of that table in the warehouse for garbled characters — a mis-detected legacy encoding is the most likely cause of mojibake.
¿Necesita ayuda? Soporte
