industry-department-solutions
Healthcare Solutions user guide
  • Overview
    • About Healthcare solutions
  • Medical Record Summarization
Este contenido no está disponible en el idioma seleccionado. Se muestra el contenido en inglés en su lugar
Policies reference
Reference for the Policies section in Medical Record Summarization, covering list metrics and columns, policy detail panels, rule tree elements, and feedback fields.
This reference covers the fields, metrics, and controls available in the Policies section of the Medical Record Summarization application.
Stats panel metrics​
MetricDescription
Total policiesNumber of policies in the tenant
ActiveNumber of policies whose current decision model generated successfully
PendingNumber of policies whose decision model is still generating
FailedNumber of policies whose decision model generation did not complete
Policy list columns​
ColumnDescription
Policy nameThe name given to the policy
Decision profileThe decision profile the policy uses
Decision model statusActive, Pending, or Failed
VersionThe current decision model version and the date it was generated
Clinician cases run on versionNumber of reviewed cases decided using the current version; displays a dash if none
Created dateThe date the policy was created
Free-text search and a Status filter appear above the table, along with a column visibility control.
Policy detail view​
The detail view provides two tabs, Editor and Feedback, a version selector, and an Edit draft action.
Policy profile panel​
ElementDescription
Profile nameThe decision profile the policy uses
Decision questionThe question the AI answers about the policy document
Decision / Data toggleSwitches the panel between the decision structure and the extracted field catalog
Score bandsScored profiles only. Each outcome with its point range.
Outcome listDirect profiles only. Each outcome with its own rule set; displays No rules yet when empty.
Scoring CriteriaThe top-level criteria in the decision model
Data tab​
Lists every field the AI extracts from the record in order to evaluate the policy. A search box filters the list.
AttributeDescription
Field nameThe name of the extracted field
Data typeThe field's type, shown as a badge - for example, boolean
How we find this in the recordDescription of the evidence the AI looks for
Used inThe scoring criteria that reference this field
Supported data types are boolean, number, categorical, text, and date.
In edit mode, the following field attributes can be changed. A field's data type cannot be changed after creation.
Field keyThe field's name
InstructionWhat the AI looks for in the record at run time
Allowed valuesCategorical fields only. The values the field may take.
Rule tree elements​
ElementDescription
Rule groupA named set of items judged together. May contain further rule groups or conditions.
ConditionA single check against extracted fields.
Evaluation qualifierBadge on each group: All are required, Any 1 is required, or First match.
Source referenceThe heading or rule identifier the item was extracted from - for example, PP-001.
Applies whenThe trigger for a scoring rule, with the points it contributes.
Points badgeThe points the item adds when met - for example, +1.
RequirementsThe field checks a condition performs, each expressed as field - must be value.
Policy document panel​
Displays the source PDF with the current page and total page count, a search box, a download control, zoom controls, an expand control, and a control to collapse the panel.
Edit mode controls​
ControlDescription
RegenerateRebuilds the rule tree from the policy document, discarding tree edits
Cancel editDiscards all changes and leaves the current version untouched
Save a new versionCommits the changes as a new numbered version. Available only once something has changed.
Edit profileOpens the decision profile for editing
Add condition groupAdds a top-level scoring criterion
Add hereInserts a rule group or condition at that position in the tree
Edit rule group / Edit conditionEdits the item's label, qualifier, or requirements
Remove rule group / Remove condition from groupDeletes the item
Drag to reorderChanges the item's order among its siblings
View in policyOpens the supporting passage in the policy document panel
Decision profile fields​
Location: policy detail view → Edit draft → Edit profile, or the decision profile step of the Add new policy wizard.
FieldRequiredDescription
Decision profile nameYesThe name of the profile
Decision questionYesThe question the AI answers as it reads the policy document. A single yes/no or which-one question.
Model typeYesDirect decision - the AI picks one of your outcomes. Scored decision - conditions contribute points that land in a score band.
OutcomesYesThe only answers the AI may give
NotesNoHints for the AI about the document type, its outcomes, and the wider context of the decision
Outcome fields​
Model typeFields per outcome
Direct decisionOutcome label, and polarity - Positive, Negative, or Neutral. Polarity affects styling only.
Scored decisionOutcome label, Min, and Max. Bands are matched top to bottom with inclusive bounds; leave the last Max blank for no upper limit.
Feedback tab​
Lists the verdicts reviewers left against this policy's decisions in the clinical review.
ColumnDescription
Policy sectionThe template section that contained the policy evaluation
SummaryThe filename of the source document
Template nameThe template that produced the summary
Template versionThe template version active at the time
ReasonThe reason the reviewer gave
Review resolutionThe completion status the review reached
WhenDate and time the feedback was submitted
ReviewerThe reviewer who submitted it
Decision modelThe decision model version the case ran against
¿Necesita ayuda? Soporte
