# Data consumption
> Data Consumption component in the Document Understanding framework, including how to use validated extracted data directly or export it as a DataSet variable.
This section includes general and technical information about the Data Consumption component.
## Data consumption Overview
### What is data consumption
Once you validate the extracted data, you can use it as it is or export it as a DataSet variable using the [Export Extraction Results](https://docs.uipath.com/activities/other/latest/document-understanding/export-extraction-results) activity.
The variable can be later saved into a DataTable format, so you can export it to whatever environment you need in order to consume it.
#### When data consumption should be used
For instance, you can easily convert the values into an Excel file, further process the data in Queues and then perform data entry into an Enterprise Resource Planning tool.
#### How to use the data consumption component
Taking this into account, the **Export Extraction Results** activity can be used with:
* **Automatic extraction results output** of the [Data Extraction Scope](https://docs.uipath.com/activities/other/latest/document-understanding/data-extraction-scope) - for RPA-based validation purposes, this is an excellent alternative of accessing the extracted data.
  :::note
  Make sure to set the **IncludeConfidence** flag to **True**.
* **Confirmed extraction results output** of the [Present Validation Station](https://docs.uipath.com/activities/other/latest/document-understanding/present-validation-station) - for downstream usage purposes, this is a straightforward means of accessing the actual values extracted through the Document Understanding<sup>TM</sup> framework.
## Data consumption related activities
### Export Extraction Results
Gives you easy access to extraction results by exporting results from an `ExtractionResult` variable to a `DataSet` variable which can be further processed. More details [here](https://docs.uipath.com/activities/other/latest/document-understanding/export-extraction-results).
