# FlexiCapture Extractor
> Use the [FlexiCapture Extractor](flexi-capture-extractor.md) if you want the extracting method to be based on a set of FlexiCapture definition files. You can find this extractor in the **UiPath.Abbyy.Activities** package.
## What Is FlexiCapture Extractor
## How to Configure
This extractor can only be used inside a [Data Extraction Scope](https://docs.uipath.com/activities/docs/data-extraction-scope) activity.
Use the [Machine Learning Extractor](data-extraction-machine-learning-extractor.md) **Configure Extractors** wizard to map all definition fields so that they can match the fields defined in Taxonomy.
Here is how the wizard looks:
![docs image](https://dev-assets.cms.uipath.com/assets/images/document-understanding/document-understanding-116543-d4a61410.webp)
Use the text boxes next to each document type in the taxonomy to specify the exact string class name (or `.fcdot` file configuration) that the **Abbyy FlexiCapture** engine reports for that particular document type.
:::important
FlexiCapture Extractor only works with an Abbyy FlexiCapture Engine Standalone installation
ABBYY FlexiCapture Engine SDK is required if you want to use the FlexiCapture Extractor activity. The engine only works with an ABBYY FlexiCapture Engine Standalone 12 license distributed by the UiPath Sales department.
The FlexiCapture activities are validated to run on FlexiCapture Engine versions 12.1.23.17,12.0.0.150 and 12.1.24.10.
The official ABBYY installation instructions can be found [here](http://help.abbyy.com/en-us/flexicapture/12/flexilayout_studio/install).
