# Migrating modern projects
> Migrate modern Document Understanding projects by exporting annotated datasets and importing them into another modern project across tenants, organizations, or into a classic project.
## Export
You can export annotated datasets from your modern project and:
* Import them into another modern project from a different tenant or organization.
* Import them into a classic project. For more information on how to import datasets into a classic project, check the [Document Understanding User Guide](https://docs.uipath.com/document-understanding/automation-cloud/latest/classic-user-guide/document-manager-import-documents) for classic projects.
  :::note
  Datasets exported from modern projects are compatible with classic projects only when training on model version 23.4.0 or newer.
For more information on how to export datasets and migrate your modern projects, check the [Migrating modern projects](https://docs.uipath.com/document-understanding/automation-suite/2.2510/user-guide/migrating-existing-modern-projects#migrating-modern-projects).
### Export data
If you want to import your project to a different tenant or organization, or backup your project, export the dataset.
1. Go to the Publish section in your project.
2. Navigate to the Export tab.
3. Select Export data.
   :::note
   Make sure that you have a project version created for the dataset you want to export.
4. Choose the document type you want to export from the Document type drop-down list.
5. Choose the project version you want to export from the Project Version drop-down list.
6. Select Export.
Once the export job is started, the dataset is being prepared for download. Once ready, a pop-up message is displayed with a Download button. Select the button to download your dataset.
![Screenshot of the Download project version button.](https://dev-assets.cms.uipath.com/assets/images/document-understanding/document-understanding-screenshot-of-the-download-project-version-button-454249-41c479cb-18737fed.webp)
You can also download the dataset at a later time or delete it from the three-dot menu next to the project version you want to download.
![Screenshot of the Export interface.](https://dev-assets.cms.uipath.com/assets/images/document-understanding/document-understanding-screenshot-of-the-export-interface-454143-11d51188-f8538f7f.webp)
## Import datasets
Once you have an exported dataset, you can import it into a different project. For more information on how to export datasets, check the [Export](https://docs.uipath.com/document-understanding/automation-suite/2.2510/user-guide/migrating-existing-modern-projects#export) section from the **Publish** page.
1. Navigate to and open the project into which you want to import data.
2. Select **Add document type** and create a new custom document type.
   :::note
   You can only import zip datasets directly in a document type.
   Figure 1. Add document type
   ![Screenshot of the Add document type interface.](https://dev-assets.cms.uipath.com/assets/images/document-understanding/document-understanding-screenshot-of-the-add-document-type-interface-393862-4826c197-351d3964.webp)
3. On the new custom document type, select **Upload** and choose the zip file of the project you exported. Wait for the upload to finish.
   Figure 2. Upload processing
   ![Screenshot of the Uploading processing loading interface.](https://dev-assets.cms.uipath.com/assets/images/document-understanding/document-understanding-screenshot-of-the-uploading-processing-loading-interface-393875-9bc56cb4-3a5cde20.webp)
Once the dataset is imported, the training starts automatically.
