# Validation Station
> Validation Station interface for reviewing and correcting document extraction results in Document Understanding, including a note on graphics driver requirements for Intel Xe GPU environments.
:::important
In case you use an Intel Xe GPU and Validation Station is not displayed properly, we recommend updating the graphics driver to the latest version. For more information, please visit [this page](https://www.intel.com/content/www/us/en/support/articles/000058136/graphics/graphics-for-11th-generation-intel-processors.html).
The Validation Station is a user interface that can be used to validate and correct data extracted from documents using the Document Understanding<sup>TM</sup> framework.
## Validation Station management
**Validation Station** can be used both as a stand-alone tool and integrated with Orchestrator/Automation Cloud Orchestrator.
Also, it can be used either as an attended activity with the **[Present Validation Station](https://docs.uipath.com/activities/other/latest/document-understanding/present-validation-station)** or as a type of action in **Action Center** with the **[Create Document Validation Action](https://docs.uipath.com/activities/other/latest/document-understanding/create-document-validation-action)**, **[Wait for Document Validation Action and Resume](https://docs.uipath.com/activities/other/latest/document-understanding/wait-for-document-validation-action-and-resume)**, as part of **Action Center Actions**.
### Requirements for document validation
Certain inputs need to be provided for the **Validation Station** to function. Here is a list with the minimum required inputs in order to configure the **Validation Station** as an attended activity:
* Provide a **Taxonomy** needed for processing the document. It can be created directly in the workflow by using the **Taxonomy Manager** wizard, and it can be loaded using the **[Load Taxonomy](https://docs.uipath.com/activities/other/latest/document-understanding/load-taxonomy)** activity. It should be provided as a `DocumentTaxonomy` variable.
* Provide the **Document Path** for the file you want to validate.
* Provide a **Document Object Model** for the file, which can be obtained as an output of the [Digitize Document](https://docs.uipath.com/activities/other/latest/document-understanding/digitize-document) activity.
* Provide the **Document Text** of the file, which can be obtained as an output of the same **Digitize Document** activity.
* Provide the **Automatic Extraction Results** which represents the data automatically extracted by the robot, that now needs human validation. This is the output of the **[Data Extraction Scope](https://docs.uipath.com/activities/other/latest/document-understanding/data-extraction-scope)** activity.
  :::note
  If no variable is provided in the **AutomaticExtractionResults** property field, or if no classification is published in the provided variable, the Validation Station opens in full manual processing mode.
### Validation Station as an attended activity
You can use the **Present Validation Station** activity anywhere in your workflows.
An attended activity is functional only if the file that needs to be processed is available locally on the machine that executes the process.
At run-time, a window opens and displays the **Validation Station** allowing any interaction from the user side.
### Validation Station in Action Center
Increase your productivity by creating an orchestration process that adds document validation actions in Action Center, in both On-Prem Orchestrator or its Automation Cloud Orchestrator counterpart. This action reduces your need for storing the documents locally, having a robot installed on each human's operated machine, or having the robot wait for human users to finish validation.
This approach requires you to have your robot connected to your **Orchestrator** and to build a project of type **Orchestration Process** in UiPath® Studio. You can publish your project to **Orchestrator** once it is ready. **[Here](https://docs.uipath.com/studio/docs/about-publishing-automation-projects)** you can find more details about this process.
When running a project with UiPath® Orchestrator, you need to make use of the **Create Document Validation Action** and **Wait for Document Validation Action and Resume** activities because this is how you are creating the connection between the unattended robots executing the automatic part and the Knowledge Workers that can pick up actions from Action Center (on-premises or cloud-based).
In this scenario, the **Validation Station** UI is displayed directly in UiPath® Orchestrator's Action Center but has the same functionalities like the one run as an attended activity.
## Learn more
Learn more about **Validation Station Wizard**, by following this [link](https://docs.uipath.com/activities/other/latest/document-understanding/present-validation-station).
