data-service
Unique record values
Data Service release notes
Última actualización 26 de jun. de 2025
Introducing the Unique value only feature: Ensure the uniqueness of all text and number records in a field, eliminating the need for complex identification methods of duplicates.
To spot uniquely constrained fields within an entity, refer to the Is Unique column.
Be aware that values in uniquely constrained text fields are case-insensitive, treating "unique_value" and "UNIQUE_value"
as duplicates.
If needed, you can easily revert by clearing the Unique values only checkbox, allowing duplicates once again.
