Última actualización 28 de abr. de 2025
Disco uipathctl rke2
Descripción
Utilidad para configurar el disco para la instalación de UiPath Automation Suite. Ejecuta este script para configurar los discos en la nueva máquina o para ampliar el tamaño del disco de datos.
uipathctl rke2 disk [flags]uipathctl rke2 disk [flags]
Ejemplos
# Configure disk for server node with in-cluster objectstore ceph
uipathctl rke2 disk --cluster-disk-name /dev/sdb --etcd-disk-name /dev/sdc --volume /dev/sdd --objectstore
# Resize file system used by monitoring stack to 60GB
uipathctl rke2 disk --resize 60 --monitoring
# Resize file system used by monitoring stack to all the space available in the datavg
uipathctl rke2 disk --resize --monitoring# Configure disk for server node with in-cluster objectstore ceph
Opciones
-s, --aicenter-disk-name string        Device partition to host local volume provisioner. Ex: /dev/sdc1. Only required for aicenter workloads on all nodes.
  -a, --aicenter-storage-extend string   Volume group extension for local volume provisioner. Ex: /dev/sdc2. Only required for aicenter workloads on all nodes.
  -z, --backup-disk-name string          Device partition to host backup. Ex: /dev/sdc1, This is required only for single node using in-cluster ceph.
  -b, --bundle-disk-name string          Device to host the uipath bundle.Only required for offline installation on 1st server node.
  -R, --ceph-raw-disk-name string        Device to host etcd, Not required for agent node. Ex: /dev/sdb.
  -c, --cluster-disk-name string         Device to host rancher and  kubelet. Ex: /dev/sdb
  -d, --debug                            Run in debug mode
      --docker-registry                  Configure logical volume and mount point for in-cluster OCI registry. Used in conjunction with -v|--volume
  -e, --etcd-disk-name string            Device to host etcd, Not required for agent node. Ex: /dev/sdb.
  -h, --help                             help for disk
      --insights                         Configure logical volume and mount point for Insights.Used in conjunction with -v|--volume
      --monitoring                       Configure logical volume and mount point for monitoring stack. Used in conjunction with -v|--volume
      --objectstore                      Configure logical volume and mount point for in-cluster objectstore: ceph. Used in conjunction with -v|--volume
      --robot-package-cache              Configure logical volume and mount point for robot package cache for non HA setup. Used in conjunction with -v|--volume
  -k, --robot-package-disk-name string   Device to host robot package cache folder. Only required for Automation Suite Robots dedicated node when 'packagecaching' is enabled
  -P, --robot-package-path string        Path to robot package cache folder (defaults to '/uipath_asrobots_package_cache' if not set)
  -r, --size int                         Resize logical volume to provided size in GB. If value is not provided, LV will be resized to consume all free space in the VG (default -1)
  -v, --volume string                    Device to host local PV, Not required for agent node. Ex: /dev/sdc.  -s, --aicenter-disk-name string        Device partition to host local volume provisioner. Ex: /dev/sdc1. Only required for aicenter workloads on all nodes.
Opciones heredadas de los comandos principales
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Descripción
  • Ejemplos
  • Opciones
  • Opciones heredadas de los comandos principales
Obtén la ayuda que necesitas
Foro de la comunidad UiPath
Confianza y seguridad
