Última actualización 28 de abr. de 2025
uipathctl config token-signing-certificates automatic-key-management disabled
Descripción
Deshabilita la gestión automática de claves para la identidad.
uipathctl config token-signing-certificates automatic-key-management disable [flags]uipathctl config token-signing-certificates automatic-key-management disable [flags]
Ejemplos
# Disable automatic key management for identity when the UiPath Automation Suite is deployed in the custom namespace
uipathctl config token-signing-certificates automatic-key-management disable --namespace custom-namespace
# Disable automatic key management for identity when the UiPath Automation Suite is deployed in the uipath namespace
uipathctl config token-signing-certificates automatic-key-management disable# Disable automatic key management for identity when the UiPath Automation Suite is deployed in the custom namespace
Opciones
  -h, --help               help for disable
    --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")  -h, --help               help for disable
Opciones heredadas de los comandos principales
      --timeout duration    timeout of the command (defaul      --context string      name of the kubeconfig context to use
  • Descripción
  • Ejemplos
  • Opciones
  • Opciones heredadas de los comandos principales
Obtén la ayuda que necesitas
Foro de la comunidad UiPath
Confianza y seguridad
