Última actualización 28 de abr. de 2025
uipathctl config alerts update-email
Descripción
Actualice el receptor de correo electrónico en Alertmanager.
uipathctl config alerts update-email [flags]uipathctl config alerts update-email [flags]
Ejemplos
# Update existing receiver in alertmanager, Pass only those parameters which needs to be update along with mandatory parameter name.
        uipathctl config alerts update-email --name test --to "admin@example.com" --from "admin@example.com" --smtp "server.mycompany.com:443" --username admin --password "somepassword" --require-tls --ca-file "file path too rootCA" --cert-file "file path too server certificate" --key-file "file path too server key file"# Update existing receiver in alertmanager, Pass only those parameters which needs to be update along with mandatory parameter name.
Opciones
--ASEA               Boolean flag to denote whether the cluster is ASEA or not
      --ca-file string     File path containing the CA certificate of the SMTP server. This parameter is optional if the CA is private
      --cert-file string   File path containing the certificate of the SMTP server. This parameter is optional if the certificate is private
      --from string        The sender's email address
  -h, --help               help for update-email
      --key-file string    File path containing the private key of the certificate for the SMTP server. This parameter is required if the certificate is private
      --name string        Name of the email configuration
      --password string    SMTP authentication Password
      --require-tls        Boolean flag to denote that TLS is enabled at the SMTP server (default true)
      --send-resolved      Boolean flag to denote whether to send email on resolved alert (default true)
      --smtp string        SMTP server URL or IP, including port
      --to string          Receiver's email address
      --username string    SMTP authentication Username      --ASEA               Boolean flag to denote whether the cluster is ASEA or not
Opciones heredadas de los comandos principales
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Descripción
  • Ejemplos
  • Opciones
  • Opciones heredadas de los comandos principales
Obtén la ayuda que necesitas
Foro de la comunidad UiPath
Confianza y seguridad
