Última actualización 13 de nov. de 2025
Puntos de conexión sanitarios
Para supervisar de forma eficaz el estado de tus servicios de Automation Suite, puedes utilizar los puntos finales de estado disponibles en esta sección. Estos puntos finales te permiten verificar rápidamente si un servicio funciona correctamente.
La siguiente tabla enumera los productos y servicios de Automation Suite y sus respectivos puntos finales de salud.
ServicioPuntos finales de estado
Plataforma
  • https://<automation-suite-fqdn>/pap_/health
  • https://<automation-suite-fqdn>/pdp_/health
  • https://<automation-suite-fqdn>/identity_/.well-known/openid-configuration
  • https://<automation-suite-fqdn>/identity_/web/
  • https://<automation-suite-fqdn>/lease_/health/
  • https://<automation-suite-fqdn>/license_/health
  • https://<automation-suite-fqdn>/organization_/health
  • https://<automation-suite-fqdn>/portal_/portal/shallow/healthStatus
  • https://<automation-suite-fqdn>/audit_/health
  • https://<automation-suite-fqdn>/resourcecatalog_/health
Action Center
  • https://<automation-suite-fqdn>/actions_/
  • https://<automation-suite-fqdn>/bupporxyservice_/health/ready
  • https://<automation-suite-fqdn>/processes_/
AI Center
  • https://<automation-suite-fqdn>/aifabric_/ai-app
  • https://<automation-suite-fqdn>/aifabric_/ai-deployer/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-trainer/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-pkgmanager/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-helper/actuator/health/ready
  • https://<automation-suite-fqdn>/aistorage_/health
Apps
  • https://<automation-suite-fqdn>/<org-name>/apps_/default/api/v1/default/system-health
Automation Hub
  • https://<automation-suite-fqdn>/automationhub_/fd-api/v1/ping
  • https://<automation-suite-fqdn>/automationstore_/fd-api/v1/ping
Data Service
  • https://<automation-suite-fqdn>/dataservice_/api/HealthCheck/health
  • https://<automation-suite-fqdn>/dataservice_/assets
Document Understanding
  • https://<automation-suite-fqdn>/du_/api/documentmanager/health
  • https://<automation-suite-fqdn>/du_/api/storage/health
  • https://<automation-suite-fqdn>/du_/api/eventservice/health
  • https://<automation-suite-fqdn>/du_/metering/alive
  • https://<automation-suite-fqdn>/du_/ocr/info/ready
  • https://<automation-suite-fqdn>/du_/extended-ocr/ready
  • https://<automation-suite-fqdn>/du_/classify/MLclassification/info/ready
  • https://<automation-suite-fqdn>/du_/svc/formextractor/info
  • https://<automation-suite-fqdn>/du_/svc/intelligentkeywords/info
Insights
  • https://<automation-suite-fqdn>/insights_/health
Servicio de notificación
  • https://<automation-suite-fqdn>/notificationservice_/notificationserviceapi/health/readiness
  • https://<automation-suite-fqdn>/notificationservice_/usersubscriptionservice/health/readiness
  • https://<automation-suite-fqdn>/notificationservice_/publishermetaservice/health/readiness
Orchestrator
  • https://<automation-suite-fqdn>/orchestrator_/api/health
Robotube
  • https://<automation-suite-fqdn>/robotube_/healthz
Control de Studio
  • https://<automation-suite-fqdn>/roboticsops_/api/health
Studio Web
  • https://<automation-suite-fqdn>/studio_/backend/healthz
  • https://<automation-suite-fqdn>/studio_/typecache/healthz/readiness
Task Mining
  • https://<automation-suite-fqdn>/taskmining_/console/api/health
  • https://<automation-suite-fqdn>/taskmining_/storage/api/health
Test Manager
  • https://<automation-suite-fqdn>/testmanager_/api/health/live
Comprobación del estado del servicio
Para comprobar el estado de un servicio específico, envía una solicitud a su punto final correspondiente, como se muestra en el siguiente ejemplo.
curl -kiso /dev/null -w "%{http_code}" https://<automation-suite-fqdn>/orchestrator_/api/healthcurl -kiso /dev/null -w "%{http_code}" https://<automation-suite-fqdn>/orchestrator_/api/health
Una respuesta correcta con un código de estado HTTP 200 indica que el servicio está en buen estado.
  • Comprobación del estado del servicio
Obtén la ayuda que necesitas
Foro de la comunidad UiPath
Confianza y seguridad
