- Información general
- Preinstalación
- Instalación
- Administración de clústeres
- Copias de seguridad y restauración
- instantánea de uipathctl
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Gestión de certificados
- obtener-certificado-saml de identidad de uipathctl
- Actualizar
- Autenticación
- Supervisión y alertas
- Solución de problemas
- salud de uipathctl
- Paquete de salud de uipathctl
- comprobación de estado de uipathctl
- uipathctl health diagnose
- uipathctl health test
Descripción
Genere un paquete de soporte que puede usar para solucionar problemas de Automation Suite .
uipathctl health bundle [PATH] [flags]
Ejemplos
# Generate the bundle in the OS temporary directory
uipathctl health bundle input.json
# Generate the bundle in a specific directory
uipathctl health bundle input.json --output-dir /foo/bar
# Generate the bundle without additional health/prereq report
uipathctl health bundle input.json --skip-diagnose
Opciones
-h, --help help for bundle
-p, --include-previous If false, skips printing the logs for the previous instance of the container in a pod if it exists. (default true)
--limit-bytes int Maximum bytes of logs to return. Defaults to no limit.
--output-dir string path to output directory
--since-time string Only return logs after a specific date (RFC3339). Defaults to all logs.
--skip-diagnose skip additional health/prereq report
--versions string path to versions file
Opciones heredadas de los comandos principales
--excluded strings components to be excluded from execution, defaults to none
--included strings components to be included in the execution, defaults to all
-o, --output output output format. one of [json,yaml,text,junit] (default text)
