Ejemplo de salida: instalación Automation Suite
The following example shows the output you may get after installing Automation Suite. For details, see Installing Automation Suite.
 ℹ️  [] Starting to apply the manifest
 ℹ️  [redis] Starting creation of component redis...
 ℹ️  [base] Installing helm component base...
 ✔️  [base] Installed helm component base
 ℹ️  [istiod] Installing helm component istiod...
 ✔️  [istiod] Installed helm component istiod
 ℹ️  [envoy-lua-lib] Installing helm component envoy-lua-lib...
 ✔️  [envoy-lua-lib] Installed helm component envoy-lua-lib
 ℹ️  [istio] Starting creation of component istio...
 ℹ️  [istio-configure] Installing helm component istio-configure...
 ✔️  [istio-configure] Installed helm component istio-configure
 ℹ️  [gateway] Installing helm component gateway...
 ✔️  [gateway] Installed helm component gateway
 ℹ️  [argocd] Installing helm component argocd...
 ✔️  [argocd] Installed helm component argocd
 ℹ️  [cert-manager] Starting creation of component cert-manager...
 ℹ️  [cert-manager] Creating Argo CD application for component cert-manager...
 ℹ️  [cert-manager] Waiting for Argo CD application for component cert-manager to synchronize...
 ℹ️  [sfcore] Starting creation of component sfcore...
 ℹ️  [sfcore] Creating Argo CD application for component sfcore...
 ℹ️  [sfcore] Waiting for Argo CD application for component sfcore to synchronize...
 ℹ️  [platform] Starting creation of component platform...
 ℹ️  [platform] Creating Argo CD application for component platform...
 ℹ️  [notificationservice] Starting creation of component notificationservice...
 ℹ️  [notificationservice] Creating Argo CD application for component notificationservice...
 ℹ️  [webhook] Starting creation of component webhook...
 ℹ️  [webhook] Creating Argo CD application for component webhook...
 ℹ️  [robotube] Starting creation of component robotube...
 ℹ️  [robotube] Creating Argo CD application for component robotube...
 ℹ️  [orchestrator] Starting creation of component orchestrator...
 ℹ️  [orchestrator] Creating Argo CD application for component orchestrator...
 ℹ️  [action_center] Starting creation of component action_center...
 ℹ️  [action_center] Creating Argo CD application for component action_center...
 ℹ️  [apps] Starting creation of component apps...
 ℹ️  [apps] Creating Argo CD application for component apps...
 ℹ️  [asrobots] Starting creation of component asrobots...
 ℹ️  [asrobots] Creating Argo CD application for component asrobots...
 ℹ️  [automation_hub] Starting creation of component automation_hub...
 ℹ️  [automation_hub] Creating Argo CD application for component automation_hub...
 ℹ️  [automation_ops] Starting creation of component automation_ops...
 ℹ️  [automation_ops] Creating Argo CD application for component automation_ops...
 ℹ️  [dataservice] Starting creation of component dataservice...
 ℹ️  [dataservice] Creating Argo CD application for component dataservice...
 ℹ️  [insights] Starting creation of component insights...
 ℹ️  [insights] Creating Argo CD application for component insights...
 ℹ️  [test_manager] Starting creation of component test_manager...
 ℹ️  [test_manager] Creating Argo CD application for component test_manager...
 ℹ️  [gatekeeper] Starting creation of component gatekeeper...
 ℹ️  [gatekeeper] Creating Argo CD application for component gatekeeper...
 ℹ️  [auth] Starting creation of component auth...
 ℹ️  [auth] Creating Argo CD application for component auth...
 ℹ️  [monitoring] Starting creation of component monitoring...
 ℹ️  [monitoring] Creating Argo CD application for component monitoring...
 ℹ️  [opa-policies] Starting creation of component opa-policies...
 ℹ️  [opa-policies] Creating Argo CD application for component opa-policies...
 ℹ️  [network-policies] Starting creation of component network-policies...
 ℹ️  [network-policies] Creating Argo CD application for component network-policies...
 ℹ️  [logging] Starting creation of component logging...
 ℹ️  [logging] Creating Argo CD application for component logging...
 ℹ️  [pushgateway] Starting creation of component pushgateway...
 ℹ️  [pushgateway] Creating Argo CD application for component pushgateway...
 ℹ️  [alerts] Starting creation of component alerts...
 ℹ️  [alerts] Creating Argo CD application for component alerts...
 ℹ️  [reloader] Starting creation of component reloader...
 ℹ️  [reloader] Creating Argo CD application for component reloader...
 ℹ️  [reloader] Waiting for Argo CD application for component reloader to synchronize...
redis created
base updated
istiod updated
envoy-lua-lib updated
istio created
istio-configure updated
gateway updated
argocd updated
cert-manager created
sfcore created
platform created
notificationservice created
webhook created
robotube created
orchestrator created
action_center created
apps created
asrobots created
automation_hub created
automation_ops created
dataservice created
insights created
test_manager created
gatekeeper created
auth created
monitoring created
opa-policies created
network-policies created
logging created
pushgateway created
alerts created
reloader created
redis created
base updated
istiod updated
istio created
gateway updated
argocd updated
sfcore created
platform created
webhook created
robotube created
apps created
asrobots created
dataservice created
insights created
gatekeeper created
auth created
monitoring created
logging created
pushgateway created
alerts created
reloader created
