# Step 5: Configuring SQL databases
> Reference for SQL database configuration requirements and supported versions for Automation Suite, including ODBC driver and SQL Server constraints.
## Databases
:::important
* Only Microsoft ODBC Driver 17 is supported.
* SQL Server 2016 and 2017 are not supported in the Automation Suite versions from 2023.10.6 to 2023.10.8. All SQL versions
are supported starting with Automation Suite versions 2023.10.9 or higher for all applications except Insights.
Unless otherwise specified in the dedicated requirements sections, these requirements are applicable to all Automation Suite products.
Each product in Automation Suite requires its own SQL database with corresponding specifications.
By default, the installer creates all the databases for you during the installation process. You must provide the necessary permissions for the installer to do so on your SQL server.
Alternatively, you can create your own databases. The following table lists the database names and their corresponding formats.
| Product / service | Default database name | Connection string format |
| Shared Platform Capabilities | `AutomationSuite_Platform` | [ADO.NET](https://docs.microsoft.com/en-us/dotnet/api/system.data.sqlclient.sqlconnection.connectionstring?view=dotnet-plat-ext-5.0#remarks) |
| Orchestrator | `AutomationSuite_Orchestrator` | [ADO.NET](https://docs.microsoft.com/en-us/dotnet/api/system.data.sqlclient.sqlconnection.connectionstring?view=dotnet-plat-ext-5.0#remarks) |
| Action Center | `AutomationSuite_Orchestrator` | [ADO.NET](https://docs.microsoft.com/en-us/dotnet/api/system.data.sqlclient.sqlconnection.connectionstring?view=dotnet-plat-ext-5.0#remarks) |
| Automation Suite Robots | `AutomationSuite_Orchestrator` | [ADO.NET](https://docs.microsoft.com/en-us/dotnet/api/system.data.sqlclient.sqlconnection.connectionstring?view=dotnet-plat-ext-5.0#remarks) |
| Automation Hub | `AutomationSuite_Automation_Hub` | [ADO.NET](https://docs.microsoft.com/en-us/dotnet/api/system.data.sqlclient.sqlconnection.connectionstring?view=dotnet-plat-ext-5.0#remarks) |
| Automation Ops | `AutomationSuite_Platform` | [ADO.NET](https://docs.microsoft.com/en-us/dotnet/api/system.data.sqlclient.sqlconnection.connectionstring?view=dotnet-plat-ext-5.0#remarks) |
| Data Service | `AutomationSuite_DataService` | [ADO.NET](https://docs.microsoft.com/en-us/dotnet/api/system.data.sqlclient.sqlconnection.connectionstring?view=dotnet-plat-ext-5.0#remarks) |
| Insights | `AutomationSuite_Insights` | [ADO.NET](https://docs.microsoft.com/en-us/dotnet/api/system.data.sqlclient.sqlconnection.connectionstring?view=dotnet-plat-ext-5.0#remarks) |
| Test Manager | `AutomationSuite_Test_Manager` | [ADO.NET](https://docs.microsoft.com/en-us/dotnet/api/system.data.sqlclient.sqlconnection.connectionstring?view=dotnet-plat-ext-5.0#remarks) |
| Task Mining | `AutomationSuite_Task_Mining` | [ADO.NET](https://docs.microsoft.com/en-us/dotnet/api/system.data.sqlclient.sqlconnection.connectionstring?view=dotnet-plat-ext-5.0#remarks) |
| AI Center | `AutomationSuite_AICenter` | [JDBC](https://docs.microsoft.com/en-us/sql/connect/jdbc/building-the-connection-url?view=sql-server-ver15) |
| Apps | `AutomationSuite_Apps` <sup>1</sup> | [ODBC](https://www.connectionstrings.com/microsoft-sql-server-odbc-driver/) |
| Document Understanding | `AutomationSuite_DU_Datamanager` | [ODBC](https://www.connectionstrings.com/microsoft-sql-server-odbc-driver/) |
| Process Mining | `AutomationSuite_ProcessMining_Metadata`  `AutomationSuite_ProcessMining_Warehouse`<sup>2</sup>  `AutomationSuite_Airflow`<sup>3 4</sup> | [ADO.NET](https://docs.microsoft.com/en-us/dotnet/api/system.data.sqlclient.sqlconnection.connectionstring?view=dotnet-plat-ext-5.0#remarks)  [PYODBC](https://docs.sqlalchemy.org/en/14/dialects/mssql.html#module-sqlalchemy.dialects.mssql.pyodbc)  [PSYCOPG2](https://docs.sqlalchemy.org/en/20/dialects/postgresql.html#module-sqlalchemy.dialects.postgresql.psycopg2) |
<sup>1</sup> The password for the Apps database must not contain `#{`.
<sup>2</sup>`AutomationSuite_ProcessMining_Warehouse` uses both ADO.NET and PYODBC formats.
<sup>3</sup>`AutomationSuite_Airflow` PostgreSQL database use SQL alchemy connection string format. The connection to the `AutomationSuite_Airflow` database **can not begin** with a `{` character.
<sup>4</sup>`AutomationSuite_Airflow` Microsoft SQL Server database use SQL alchemy connection string format. `AutomationSuite_Airflow` **must** have `READ_COMMITTED_SNAPSHOT` enabled when creating databases manually. The connection to the `AutomationSuite_Airflow` database **can not begin** with a `{` character.
If you choose to bring your own databases for a new Automation Suite installation, we strongly recommend setting up new databases rather than using existing ones. This precaution is necessary to prevent any conflicts with the operation of Automation Suite that might occur due to leftover metadata from old databases.
For Process Mining on Automation Suite 2023.10.9 or higher versions, you are recommended to use PostgreSQL for `AutomationSuite_Airflow`.
If you manually set the connection strings in the configuration file, you can escape SQL, JDBC, or ODBC passwords as follows:
* for SQL: add `'` at the beginning and end of the password, and double any other `'`.
* for JDBC/ODBC: add `{` at the beginning of the password and `}` at the end, and double any other `}`.
You can also use the databases in an elastic pool for better cost-effectiveness.
### SQL collation
Automation Suite supports SQL collation set to `SQL_Latin1_General_CP1_CI_AS` at both the server and database level. We strongly recommend this particular setup for optimum performance and stability.
While you have the flexibility to use a collation of your choice, be aware that untested configurations can potentially lead to unexpected issues.
:::important
We do not recommend using Binary SQL or any collations that are case-sensitive, as they cause known issues while installing Automation Suite.
## Permissions
If you want the installer to create a database on the provided SQL server, make sure to grant at least the `dbcreator` role to the SQL account used to connect to the database.
If you want to create your own databases for all the products, you must grant the SQL account the `db_owner` role for all Automation Suite databases.
If security restrictions do not allow the use of `db_owner`, then the SQL account must have the following roles and permissions on all databases (the only exception is Insights which still requires `db_owner`).
* `db_securityadmin`
* `db_ddladmin`
* `db_datawriter`
* `db_datareader`
* `EXECUTE` permission on dbo schema
We only use the `db_securityadmin` and `db_ddladmin` roles during installation or if the databases are reprovisioned, so you may revoke these permission afterwards.
## SQL server ciphers
Only the listed SQL ciphers are supported in Automation Suite:
* `TLS_AES_256_GCM_SHA384`
* `TLS_CHACHA20_POLY1305_SHA256`
* `TLS_AES_128_GCM_SHA256`
* `TLS_AES_128_CCM_SHA256`
* `ECDHE-ECDSA-AES256-GCM-SHA384`
* `ECDHE-RSA-AES256-GCM-SHA384`
* `ECDHE-ECDSA-CHACHA20-POLY1305`
* `ECDHE-RSA-CHACHA20-POLY1305`
* `ECDHE-ECDSA-AES256-CCM`
* `ECDHE-ECDSA-AES128-GCM-SHA256`
* `ECDHE-RSA-AES128-GCM-SHA256`
* `ECDHE-ECDSA-AES128-CCM`
* `ECDHE-ECDSA-AES128-SHA256`
* `ECDHE-RSA-AES128-SHA256`
* `ECDHE-ECDSA-AES256-SHA`
* `ECDHE-RSA-AES256-SHA`
* `ECDHE-ECDSA-AES128-SHA`
* `ECDHE-RSA-AES128-SHA`
* `AES256-GCM-SHA384`
* `AES256-CCM`
* `AES128-GCM-SHA256`
* `AES128-CCM`
* `AES256-SHA256`
* `AES128-SHA256`
* `AES256-SHA`
* `AES128-SHA`
* `DHE-RSA-AES256-GCM-SHA384`
* `DHE-RSA-CHACHA20-POLY1305`
* `DHE-RSA-AES256-CCM`
* `DHE-RSA-AES128-GCM-SHA256`
* `DHE-RSA-AES128-CCM`
* `DHE-RSA-AES256-SHA256`
* `DHE-RSA-AES128-SHA256`
* `DHE-RSA-AES256-SHA`
* `DHE-RSA-AES128-SHA`
* `PSK-AES256-GCM-SHA384`
* `PSK-CHACHA20-POLY1305`
* `PSK-AES256-CCM`
* `PSK-AES128-GCM-SHA256`
* `PSK-AES128-CCM`
* `PSK-AES256-CBC-SHA`
* `PSK-AES128-CBC-SHA256`
* `PSK-AES128-CBC-SHA`
* `DHE-PSK-AES256-GCM-SHA384`
* `DHE-PSK-CHACHA20-POLY1305`
* `DHE-PSK-AES256-CCM`
* `DHE-PSK-AES128-GCM-SHA256`
* `DHE-PSK-AES128-CCM`
* `DHE-PSK-AES256-CBC-SHA`
* `DHE-PSK-AES128-CBC-SHA256`
* `DHE-PSK-AES128-CBC-SHA`
* `ECDHE-PSK-CHACHA20-POLY1305`
* `ECDHE-PSK-AES256-CBC-SHA`
* `ECDHE-PSK-AES128-CBC-SHA256`
* `ECDHE-PSK-AES128-CBC-SHA`
* `RSA-PSK-AES256-GCM-SHA384`
* `RSA-PSK-CHACHA20-POLY1305`
* `RSA-PSK-AES128-GCM-SHA256`
* `RSA-PSK-AES256-CBC-SHA`
* `RSA-PSK-AES128-CBC-SHA256`
* `RSA-PSK-AES128-CBC-SHA`
## SQL requirements for Full-Text Search
Document Understanding requires the SQL Server to have the Full-Text Search component of the SQL Server Database Engine, which is not always installed by default.
If you did not select Full-Text Search when you installed SQL Server, run SQL Server Setup again to add it before configuring Document Understanding.
For more info, check this guide on how to [add/install features on SQL server](https://docs.microsoft.com/en-us/sql/database-engine/install-windows/add-features-to-an-instance-of-sql-server-setup?view=sql-server-2017#to-add-features-to-an-instance-of-). You can also check [here](https://docs.microsoft.com/en-us/sql/sql-server/editions-and-components-of-sql-server-2017?view=sql-server-2017#deciding-among--components) all the components that can be added to the SQL Server, which includes also Full-Text Search.
## SQL requirements for Insights
:::note
Insights does not support Azure AD authentication. If you authenticate using Azure AD, dashboards cannot be loaded and data cannot be fetched from the Microsoft SQL database.
Insights requires SQL Server 2019 or 2022, including support for columnstore index and `.json` functions. SQL Server Enterprise is recommended due to more efficient threading and scalability.
For Azure SQL, ensure the database is S3 service objective or higher.
Make sure the compatibility level for Insights database is set to 130 or higher. In most cases, the default settings meet this requirement. For more info, refer to [View or Change the Compatibility level of a Database - SQL Server](https://docs.microsoft.com/en-us/sql/relational-databases/databases/view-or-change-the-compatibility-level-of-a-database?view=sql-server-ver15).
The installation validates both conditions and alerts you if minimum requirements are not met.
## SQL requirements for Data Service
Data Service requires SQL Server version 2016 or higher.
If you create your own database using SQL Server version 2019 or higher, make sure to grant the following Data Service permissions to your users:
GRANT ALTER ANY SENSITIVITY CLASSIFICATION TO {userName};
GRANT VIEW ANY SENSITIVITY CLASSIFICATION TO {userName};
## SQL requirements for Process Mining
When you enable Process Mining for installation on Automation Suite 2023.10.9 or higher you can choose to bring either a PostgreSQL database or a Microsoft SQL Server database for `AutomationSuite_Airflow`.
:::important
For Process Mining on Automation Suite 2023.10.9 or higher versions, you are recommended to move to PostgreSQL for the `AutomationSuite_Airflow` database, as PostgreSQL runs with the latest versions of Apache Airflow. Running the latest version of Airflow ensures you make use of new functionality, performance, and security fixes.
If you choose not to use a PostgreSQL database and keep using a Microsoft SQLServer database, Process Mining on Automation Suite will run with legacy Airflow. Legacy versions of Apache Airflow may lack functionality, performance, and security fixes.
Starting with Process Mining on Automation Suite 2025.10 only PostgreSQL database is supported for the `AutomationSuite_Airflow` database.
### `AutomationSuite_Airflow` PostgreSQL database
For Process Mining on Automation Suite 202310.9 or higher versions, you can choose to use a PostgreSQL database for the `AutomationSuite_Airflow` database.
When migrating from Microsoft SQL Server to PostgreSQL database, data migration is not required. With a correct configuration setup, the database is rebuilt when running Sync Airflow.
#### Supported PostgreSQL versions
PostgreSQL versions 12.x to 16.x are supported. It is recommended to use the most recent version of PostgreSQL within this range for optimal compatibility and performance.
#### Hardware requirements
The machine on which the PostgreSQL database for Airflow is installed must meet the following harware requirements.
* **Cores:** 4
* **Memory:** 16 GiB
* **Storage:** 64 GiB
* **IOPS:** &gt;=500 IOPS
#### Required permissions
The PostgreSQL Airflow user (or any dedicated database user) must have
* "All Privileges" permissions for the designated Airflow database.
* "all grants" on the server's public schema.
* "search_path" set to "public".
:::note
You may need to update PostgreSQL Host-Based Authentication file `pg_hba.conf` to add the Airflow user to the database access control list and reload the database configuration to apply the changes.
The following code shows an example for setting up a PostgreSQL database.
CREATE DATABASE airflow_db
  WITH ENCODING 'UTF8'
  LC_COLLATE='en_US.UTF-8'
  LC_CTYPE='en_US.UTF-8'
  TEMPLATE template0;
CREATE USER airflow_user WITH PASSWORD 'airflow_pass';
GRANT ALL PRIVILEGES ON DATABASE airflow_db TO airflow_user;
-- PostgreSQL 15 requires additional privileges:
GRANT ALL ON SCHEMA public TO airflow_user;
The following code shows a database encoding validation example.
SELECT pg_encoding_to_char(encoding) AS encoding
FROM pg_database
WHERE datname = 'airflow_db';
Refer to the official [Airflow documentation](https://airflow.apache.org/docs/apache-airflow/stable/howto/set-up-database.html#setting-up-a-postgresql-database) for more information on how to set up a PostgreSQL database for Airflow.
#### Default server port
The default server port for Airflow database connections with PostgreSQL is `5432`. If you are using the PgBouncer connection pooler, it is common to use port `6432`.
The following code blocks show some example connection strings for PostgreSQL using port `5432`.
Sample connection string:
postgresql+psycopg2://testadmin:<password>@test-cu231009v3-postgresql.postgres.database.azure.com:5432/automationsuite_airflow
Sample connection string for using Kerberos:
postgresql+psycopg2://kerberos_user:@kerberospostgres.AUTOSUITEAD.LOCAL:5432/automationsuite_airflow
Sample connection string for using Managed Identitiy:
postgresql+psycopg2://testmanagedidentity:@test-postgresql-1.postgres.database.azure.com/airflow-ci-sfasaksqacu8524745
The default server port can be configured to use any available port as per your system requirements.
#### PgBouncer
Since Airflow uses short-lived connections, it is highly recommended to set up PgBouncer. PgBouncer is a lightweight connection pooler for PostgreSQL.
Refer to the official [PgBouncer documentation](https://www.pgbouncer.org/config.html) for more information on how to set up PgBouncer.
### `AutomationSuite_Airflow` Microsoft SQL Server database
:::note
For the `AutomationSuite_Airflow` database, Microsoft SQL Server is the only option available for Process Mining on Automation Suite versions 2023.10.8 and earlier. For Process Mining on Automation Suite 2023.10.9 or higher versions, you are recommended to move to PostgreSQL.
If you use Microsoft SQL Server for `AutomationSuite_Airflow` database, make sure you meet the following requirements.
:::important
You must use the default server port `1433` for Airflow database connections. Non-standard SQL Server ports are not supported.
:::note
When setting up Microsoft SQL Server make sure that the timezone of the SQL Server machine where the Airflow database is installed, is set to UTC.
### `AutomationSuite_ProcessMining_Warehouse` database
Process Mining on Automation Suite requires a separate Microsoft SQL Server for the `AutomationSuite_ProcessMining_Warehouse` for data storage for Process Mining process apps.
:::important
To ensure proper functioning of Process Mining, it is recommended to use Microsoft SQL Server 2022.
This is an overview of hardware requirements and recommendations for setting up a Microsoft SQL Server database machine for `AutomationSuite_ProcessMining_Warehouse`.
To calculate the hardware requirements, you need to have an indication of:
* the number of (million) events in your process.
* the number of case and event fields in your output data. In a development environment, for performance reasons, it is recommended to work on a small development dataset with a limited number of records.
You can use the [UiPath Automation Suite Install Sizing Calculator](https://docs.uipath.com/automation-suite/automation-suite/2023.10/installation-guide/capacity-planning#capacity-planning) to determine the hardware requirements for setting up a dedicated Microsoft SQL Server machine for Process Mining. When you add Process Mining to the **Product section**, the minimum requirements for 1 Dedicated SQL Server are displayed. For details, refer to [Hardware requirements](https://docs.uipath.com/process-mining/automation-suite/2023.10/user-guide/hardware-requirements).
The SQL user used in the connection strings must have the `db_securityadmin` database-level role both during and post-installation to enable per app security on the Process Mining data warehouse SQL Server. For details, refer to the official Microsoft documentation on [Database-level roles](https://learn.microsoft.com/en-us/sql/relational-databases/security/authentication-access/database-level-roles?view=sql-server-ver16) and [Configuring process app security](https://docs.uipath.com/automation-suite/automation-suite/2023.10/installation-guide/configuring-process-app-security-).
## SQL requirements for AI Center
### Requirements for AI Center connected to an external Orchestrator
If you install an AI Center that connects to an external Orchestrator, you must ensure you create a new database named `AutomationSuite_Platform` for AI Events and AI Storage services.
### Requirements for AI Center installed on a FIPS 140-2-enabled machine
To install AI Center on a FIPS 140-2-enabled machine, take the following steps:
1. Before starting the Automation Suite installation, take the following steps:
   1. Enable FIPS 140-2 on the machine on which you plan to install Microsoft Server by following the [Microsoft instructions](https://learn.microsoft.com/en-us/troubleshoot/sql/database-engine/security/sql-2016-fips-140-2-compliant-mode#windows-system-administration-requirements).
   2. Install Microsoft SQL Server on the FIPS 140-2-enabled machine.
   3. Get the Microsoft SQL Server certificate by running the following command from the SQL Server or any server that can connect to the SQL server with the configured SQL host name:
      nmap -sV -p <port> -vv --script ssl-cert domain
2. During the Automation Suite installation, take the following steps:
   1. Append the following values to the AI Center `sql_connection_string_template_jdbc` connection string in the `cluster_config.json` file: `encrypt=true;trustServerCertificate=false;fips=true;`.
      Example:
      jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;fips=true;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"
      For details on database configuration, refer to [Advanced installation experience](https://docs.uipath.com/automation-suite/automation-suite/2023.10/installation-guide/database-configuration#bring-your-own-databases) and [Updating the SQL database](https://docs.uipath.com/automation-suite/automation-suite/2023.10/installation-guide/updating-the-sql-database#updating-the-connection-strings-for-installed-products).
   2. Add the exported cert from step 1.c. to the trust store of the host machine. For details refer to [Updating the CA Certificates](https://docs.uipath.com/automation-suite/automation-suite/2023.10/installation-guide/managing-the-certificates#updating-the-ca-certificates).
## SQL requirements for HA
For a high-availability configuration of your SQL Server, select an Always On availability group. For more info, refer to [Overview of Always On availability groups](https://docs.microsoft.com/en-us/sql/database-engine/availability-groups/windows/overview-of-always-on-availability-groups-sql-server?view=sql-server-ver16).
## SQL requirements for Orchestrator
:::important
To increase performance, avoid deadlocks, and prevent dirty reads in SQL, make sure that the `READ_COMMITTED_SNAPSHOT` option is set to `ON`.
Use this query to check if `READ_COMMITTED_SNAPSHOT` is enabled or disabled:
SELECT is_read_committed_snapshot_on FROM sys.databases
   WHERE name like 'PLACEHOLDER'
Make sure to replace PLACEHOLDER with your Orchestrator database name.
If it is enabled, the returned value will be `1`.
If it is disabled, the returned value will be `0`. Use this query to enable it:
ALTER DATABASE PLACEHOLDER
SET READ_COMMITTED_SNAPSHOT ON
If you use different databases for Test Automation and/or Update Server, `READ_COMMITTED_SNAPSHOT` must be enabled on those as well.
