# Get message template
> API reference for retrieving a specific message template by template ID in Automation Suite.
Returns a message template, based on the template ID.
## API endpoint
`GET` `https://{yourDomain}/{organizationName}/identity_/api/MessageTemplate/{templateId}`
## Scopes
Requires the following scopes:
* `PM.MessageTemplate`
* `PM.MessageTemplate.Read`
## Request headers
## Path parameters
| Parameter | Data type | Description |
| `templateId` | String | **Required.**The ID of message template you want to retrieve. |
## Responses
### 200 OK
Returns the message template information, such as message ID, the message title, and the content.
  "id": 0,
  "name": "string",
  "value": "string"
