Ejecución de requisitos previos de uipathctl rke2
Ejecuta comprobaciones de requisitos previos específicos de RKE2 en Automation Suite en Linux.
Descripción​
Ejecuta las comprobaciones de requisitos previos específicas de RKE2.
uipathctl rke2 prereq run PATH [flags]
Opciones​
  -h, --help               help for run
  -m, --machines strings   Comma separated IP address / hostnames of all the machines to run connectivity check against
      --node-type string   Possible values [server|agent|task-mining|asrobots|gpu]. Defaults to server (default "server")
      --only string        If set, limits the scope of the command to a specific check (e.g., 'rpm')
  -o, --output output      Output format. One of [json,yaml,text]. Defaults to text (default text)
  -v, --verbose            verbose output
      --versions string    path to versions file
Opciones heredadas de los comandos principales​
      --excluded strings    components to be excluded from execution, defaults to none
      --included strings    components to be included in the execution, defaults to all
      --upgrade             include upgrade-related checks
  • Descripción​
  • Opciones​
  • Opciones heredadas de los comandos principales​
¿Necesita ayuda? Soporte
