Disco uipathctl rke2
Configure los discos para la instalación de Automation Suite o amplíe el tamaño del disco en Linux.
Descripción​
Utilidad para configurar el disco para la instalación de UiPath Automation Suite. Ejecuta este script para configurar los discos en la nueva máquina o para ampliar el tamaño del disco de datos.
uipathctl rke2 disk [flags]
Ejemplos​
# Configure disk for server node with in-cluster objectstore ceph
uipathctl rke2 disk --cluster-disk-name /dev/sdb --etcd-disk-name /dev/sdc --volume /dev/sdd --objectstore
# Resize file system used by monitoring stack to 60GB
uipathctl rke2 disk --resize 60 --monitoring
# Resize file system used by monitoring stack to all the space available in the datavg
uipathctl rke2 disk --resize --monitoring
Opciones​
  -s, --aicenter-disk-name string        Device partition to host local volume provisioner. Ex: /dev/sdc1. Only required for aicenter workloads on all nodes.
  -a, --aicenter-storage-extend string   Volume group extension for local volume provisioner. Ex: /dev/sdc2. Only required for aicenter workloads on all nodes.
  -z, --backup-disk-name string          Device partition to host backup. Ex: /dev/sdc1, This is required only for single node using in-cluster ceph.
  -b, --bundle-disk-name string          Device to host the uipath bundle.Only required for offline installation on 1st server node.
  -R, --ceph-raw-disk-name string        Device to host etcd, Not required for agent node. Ex: /dev/sdb.
  -c, --cluster-disk-name string         Device to host rancher and  kubelet. Ex: /dev/sdb
  -d, --debug                            Run in debug mode
      --docker-registry                  Configure logical volume and mount point for in-cluster OCI registry. Used in conjunction with -v|--volume
  -e, --etcd-disk-name string            Device to host etcd, Not required for agent node. Ex: /dev/sdb.
  -h, --help                             help for disk
      --insights                         Configure logical volume and mount point for Insights.Used in conjunction with -v|--volume
      --monitoring                       Configure logical volume and mount point for monitoring stack. Used in conjunction with -v|--volume
      --objectstore                      Configure logical volume and mount point for in-cluster objectstore: ceph. Used in conjunction with -v|--volume
      --robot-package-cache              Configure logical volume and mount point for robot package cache for non HA setup. Used in conjunction with -v|--volume
  -k, --robot-package-disk-name string   Device to host robot package cache folder. Only required for Automation Suite Robots dedicated node when 'packagecaching' is enabled
  -P, --robot-package-path string        Path to robot package cache folder (defaults to '/uipath_asrobots_package_cache' if not set)
  -r, --size int                         Resize logical volume to provided size in GB. If value is not provided, LV will be resized to consume all free space in the VG (default -1)
  -v, --volume string                    Device to host local PV, Not required for agent node. Ex: /dev/sdc.
Opciones heredadas de los comandos principales​
  • Descripción​
  • Ejemplos​
  • Opciones​
  • Opciones heredadas de los comandos principales​
¿Necesita ayuda? Soporte
