Ejemplo de Cluster_config.json
Referencia para el archivo de configuración de ejemplo cluster_config.json y sus parámetros en Automation Suite.
  "fqdn": "PLACEHOLDER",
  "cluster_fqdn": "PLACEHOLDER",
  "fixed_rke_address": "PLACEHOLDER",
  "admin_username": "PLACEHOLDER",
  "admin_password": "PLACEHOLDER",
  "rke_token": "PLACEHOLDER ",
  "zone_resilience": false,
  "registries": {
    "docker": {
      "url": "registry.uipath.com"
    "helm": {
  "sql_connection_string_template": "PLACEHOLDER",
  "sql_connection_string_template_jdbc": "PLACEHOLDER",
  "sql_connection_string_template_odbc": "PLACEHOLDER",
  "sql_connection_string_template_sqlalchemy_pyodbc": "PLACEHOLDER",
  "orchestrator": {
    "testautomation": {
      "enabled": true
    "updateserver": {
      "enabled": true
    "enabled": true
  "infra": {
    "docker_registry": {
      "username": " PLACEHOLDER ",
      "password": " PLACEHOLDER "
     "pod_log_path": ""
  "platform": {
    "enabled": true
  "automation_hub": {
    "enabled": true
  "automation_ops": {
    "enabled": true
  "action_center": {
    "enabled": true
  "aicenter": {
    "enabled": true
  "documentunderstanding": {
    "enabled": true,
    "datamanager": {}
  "apps": {
    "enabled": true
  "test_manager": {
    "enabled": true
  "insights": {
    "enabled": true
  "integrationservices": {
    "enabled": true
  "dataservice": {
    "enabled": true
  "asrobots": {
    "enabled": true,
    "packagecaching": true,
    "packagecachefolder": "/uipath_asrobots_package_cache"
  "processmining": {
    "enabled": true
  "external_object_storage": {
    "enabled": false
  "identity_certificate": {},
  "profile": "ha",
  "network": {
    "ipv4": { "enabled": true },
    "ipv6": { "enabled": true }
  "telemetry_optout": false,
  "alternative_fqdn": "",
  "server_certificate": {
    "ca_cert_file": "/opt/UiPathAutomationSuite/UiPath_Installer/rootCA.crt",
    "tls_cert_file": "/opt/UiPathAutomationSuite/UiPath_Installer/server.crt",
    "tls_key_file": "/opt/UiPathAutomationSuite/UiPath_Installer/server.key"
  "alternative_certificate": {
    "ca_cert_file": "/opt/UiPathAutomationSuite/UiPath_Installer/alt-rootCA.crt",
    "tls_cert_file": "/opt/UiPathAutomationSuite/UiPath_Installer/alt-server.crt",
    "tls_key_file": "/opt/UiPathAutomationSuite/UiPath_Installer/alt-server.key"
  "istioMinProtocolVersion": "TLSV1_3"
  "registries": {
    "docker": {
    "helm": {
  "orchestrator": {
    "testautomation": {
      "enabled": true
    "updateserver": {
      "enabled": true
    "enabled": true
  "infra": {
     "pod_log_path": ""
  "platform": {
    "enabled": true
  "automation_hub": {
    "enabled": true
  "automation_ops": {
    "enabled": true
  "action_center": {
    "enabled": true
  "aicenter": {
    "enabled": true
    "enabled": true,
    "datamanager": {}
  "apps": {
    "enabled": true
  "test_manager": {
    "enabled": true
  "insights": {
    "enabled": true
    "enabled": true
  "dataservice": {
    "enabled": true
  "asrobots": {
    "enabled": true,
  "processmining": {
    "enabled": true
    "enabled": false
  "profile": "ha",
  "network": {
¿Necesita ayuda? Soporte
